Just ordered a Blazer Carbon Fibre Bonnet and Some Bonnet Pins! Cant wait fit it.
For those of you who dont know, my current stock bonnet had relations with my windscreen and my roof.
Its my first step inside the carbon circle, wonder if it stops there haha.
Nice... Carbon is the shizznit. :P
I hope you dont get defected and have to get it passed over the pits though...
I nearly went the carbon fibre bonnet when mine got damaged on a trip back from Sydney... Problem was I couldn't get any gaurantees from anyone as to whether it'd void my insurance in an accident especially if it shattered and cut someone.
So I went the boring way and got it fixed. They do look hot though!
just get a factory looking carbon bonnet that is painted the same as the rest of the car. light weight and stealthy.
So by that you dont mean Glossed raw carbon with big aggresive nostril vents like the one I ordered :P
Thanks shell :(
P.S. if anyone is after some www.skylinesaustralia.com stickers, ive got 2 that im not using and probably wont be using any time soon (wouldnt really suit on a ford?), if you want them let me know. theyre silver/grey, and theyre free! i dont know the sizes but theyre the smaller ones.
P.P.S Let me know if im not allowed to give these away, if there only for donating members etc...
:) I'll take those Beau
was that sarcasm? god Beau I didn't mean someone like you.. you're still around sometimes and are far from annoying.. I meant like a total random
Oh right, my bad...
hmmmm ill have to think about it... i ment any OTHER member would get them for free... :(
Call me when you want them or i can drop em over tomorrow arv...
would've but then i woulda had to have paid for actual customised plates :)
i did the best with what i had.
it was either that or RB 020 and whos proud of a stocker 20 ;)
GUS!! - You are a Skyline owner you should be proud of it regardless of what the motor has done to it!!!11one :P
I think you should have gone for - GUS R32 - that would have been cool ;)
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
