Nah been logging into shared computers so maybe it left my name in there or something (although I'm always really careful to log out!)
Just pisses me off cos I can't fix it (which means I can't use it) till I get home on Saturday! :(
Hope no one from SAU was the victim here :D
ACT Policing has arrested four people and recovered three stolen motor vehicles after a distinctive stolen light blue Ford Falcon GT was sighted by police in a Yarralumla backyard.
The Ford GT was one of two vehicles stolen during a burglary at a Chifley home in the early hours of today (November 10). The second vehicle was a Nissan 350Z, both vehicles were stolen using the keys taken during the burglary.
Police discovered the GT around 1pm today, after it had been reported that a male had allegedly assaulted another man at the Narrabundah shops before driving off in the Falcon.
A short time later police on patrol in Yarralumla sighted a male who ran from police leading them to the rear yard of the premises where the stolen GT was located. Three males were located with the vehicle and subsequently arrested. The first male, identified as a 21-year-old Narrabundah man fled the scene. He was later identified driving a suspected stolen motor vehicle in Kingston and was arrested by police.
A few streets away from the Yarralumla address the Nissan 350Z was recovered containing property suspected to have been stolen from another burglary at a restaurant in Kingston also in the early hours of the morning.
Three men and one juvenile male will face the ACT Magistrates Court and ACT Children’s Court tomorrow (November 11) charged with multiple property crime and traffic offences.
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
