so i'm looking around the room i'm in trying to find something interesting i can post about.
got nothing.
oh yeah! on tonight's episode of At Home with Julia, there's a controversial scene, involving Julia and her husband (whatever his name is) having SEX
and then after sex they drape themselves in the Aussie FLAG!!!!
heard the news on Tripe J today. they said the scene has been raised in parliament and that the Coalition is calliing for an evaluation of ABC funding. I say it's self-promotion. Which is why i'm going to watch that show on tv now!
good night skyliners.
I didn't catch it but saw it on the news briefly and had a laugh. They were talking about how inappropriate it is and wondering if she's getting less respect because she's a woman.
I just think there's a lack of respect because she's an idiot but each to their own!
Can't think why you'd buy a bikini that you can only wear for a couple of hours per year...
Anyway, what do you think of Google + ? I haven't seen it yet. I hope their IM system Is better than fb.
IF they wanna flaunt in a nice bikini, even if only for a couple hours a year, who are we to complain?
I like G+ much more than fb, no apps, no adds.. The chat uses googletalk, to if you have ever used that in your gmail acct, it is the same. And it also keeps chat history (which you can disable), and you can use voice and vid chat through it too.
