Thats pretty much it, if you have bad luck and get done for defects, its tricky to get out of it with your mortgage intact.
Ive always lived here, when you dont have to pass the car every year, it gets more modified.
Ive had vehicles registered that go 260kph but so crap the exhaust falls off, its weird putting z rated tires on a shitbox.
However being a tradie i drive a ute every day(more mods) and dont seem to attract their attention.
Troy if your totally legal and everything engineered, thats hard to get, be proud. And enjoy peace of mind.
by the way 2 anchor points? did you get twins? that would be cool. :thumbsup:
haha yeah 2 anchor points. He did it so 'by the book' that he checks the vehicle plate to see if it's a 4 seater (2 points) or a 5 seater (3 points).
That's exactly it too, it will be entirely engineered except for when I put my exhaust ant BOV back on, which have never given me troubles anyway. Other than those 2 things, nothing about how the car sits right now is defectable.
Goodbye old faithful.
The ute is sold, had her for about 10 years, many great memories, like drifting on the dirt, in the dark, snowing, all the way to Adaminaby.
And hauling the bikes up to the brindies on those crisp, clear winter mornings.
However all the proceeds are going into the Skyline.
So funds to get ready for SAU nats in november.
Cosmetics or mechanicals... hmm.
Alrighty. Booked into Dickson tomorrow for what SHOULD be the final inspection. Everything they failed me on for this current roadworthy has been rectified, so logic says I have nothing at all to worry about as it will pass.
THE SUSPENSE IS KILLING ME!
Fingers crossed for ya Troy, dicksons new thing is getting a different inspector the second or third time around and they deside to look for more that was missed on intial inspection to out do the other inspector and big note themselves, kind of a "so and so missed this and this, I have to do his job because he can't do it properly". Happened to 2 mates in the last few months.
f**king hell. I'll near on kill someone if this happens.
EDIT: actually come to think of it, they did do this in a way...the second time I went through there wasn't on the same roadworthy, but I had fixed everything they failed the first time....however this time they picked up on the rear window tint, hole in boot floor and child restraints.
Shouldn't they ONLY check that I fixed the things I was previously failed for? Or is that too logical? lol
There's only 2 more things that I can possibly fathom they can still fail me on, one of which they were trying to determine last time but couldn't see it well enough to conclusively pick on it.
So how much has it cost you all up to get your car engineered?
Well it's hard to put a figure on it precisely...So we'll go with somewhere over $2500 inclusive of fabricating and fitting child restraints.
So without the child restraints it is considerably less.
What mods did you get engineered? Turbo, coilovers, wheels, fmic come to mind but was there much else they had to do?
Well the report covers the whole car - ie you can't ask him to engineer your coilovers while ignoring an engine swap or something. The report itself came in at $1350 ish, though a small part of this is due to having to fix a few things up then pay for reassessment of said things.
The scope of modifications covered in my ORIGINAL report are coilovers, rear camber arms, rear traction rod, HICAS lock bar, non-standard wheels, steering wheel (lol), brake lines, and turbo. There's also sundry additions like FMIC, dash gauges, pod filter inside cold air box, and oil catch can.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
