Situational I think. If you're in the left hand lane and they're quite clearly an arrogant f**khead (male) or just some stupid mindless drone (woman), then yeah f**k them - slow down to be annoying lol.
If you're in the right hand lane and overtaking at a decent speed above the limit, again f**k them....
  • Like 1
Glad you agree!
Because I have had both situations.
The overtaking one gets me the most annoyed.
Doing 110-115 overtaking and they are right up you arse. These are the ones I don't slam my brakes on but instead I just give them the finger.
The ones in the left lane I either tap my brakes or I slow down to a very slow speed until they overtake
  • Like 1
Are there any people here that have used any panel beaters in Canberra and would recommend them? Tax return has come in and will start getting quotes for the damage this week :)
Unless its a Ferrari etc
I wasnt serious. But i do understand if its a show car.
Lots of 4wds and utes with dirtbikes on brindabella rd today, people going for a look at some snow.
However its doing the typical thing, nice and sunny at the cotter but up at mt Coree where the snow is, its still like a blizzard.
Been there on a bike before and its NASTY up there. The ice flies sideways and finds the gap in your armour.
Kelly body in Mitchell are pretty good and decently priced.
  • Like 1
That's going to bring some unwanted heat to the poor VIC guys, as if they don't already cop enough.
Hate how they made mention it was a Nissan skyline but then the other car who ran away from police in the white commo didn't get a mention of the type of car they were driving.
I'm not overly fussed on the conditions of the snow, as that's down the priority list behind partying and bishes. Though if the conditions are remotely acceptable I'll be hitting the slopes Sunday for sure - haven't been snowboarding for 2 years exactly as of today LOL
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
