NSW are now allowing P-Platers to drive Turbocharged cars.
Link: http://smh.drive.com.au/motor-news/nsw-backflips-on-pplate-turbo-ban-20130807-2rg9o.html
NSW is set to overturn a ban preventing P-platers from driving the latest turbocharged fuel efficient vehicles.
Provisional drivers in NSW will be subject to fairer vehicle guidelines from next year, with the state government due to adopt a national framework that better reflects vehicle performance.
Under changes to be rolled out as early as January, a contentious blanket ban on turbocharged and supercharged vehicles will be replaced by a formula that calculates the power-to-weight ratio of a car with a limit of 130kW/tonne, opening up a plethora of low-powered vehicles for P-platers that use turbo-chargers to save fuel
Yeah not sure. Each state as their own road laws so it wouldn't suprise me that it's at a state level.I wonder if it is for new cars using that formula or if it'll be for older cars as well.
I wonder if that would include something like an XT Forester. I was driving one on my P's and legally should not have been, but never got a second look by police.
It raises an interesting point though. The XT engine etc. is the same as the WRX's and in some cases bigger displacement and turbo depending on the year of WRX.
I always wonder why driver education is not taught in school prior to being of age for a licence.
In the US they have driver ed in schools, have done for a very long time. It used to include a trip to hospital to visit people seriously injured in car accidents etc. as well as driver training.
I always wondered that too cause I think that'd be an awesome idea.
my school did that.
Without subsidies on offer, these programs are only ever attended by INTELLIGENT members of the driving community - which unfortunately make up such a ridiculously small percentage of the 'problem' drivers, since those drivers are simply complete morons haha
  • Like 1
When i had my first car, id see the bloodstained wrecks at the wreckers as i was getting parts.
Some had bits of skin and hair :sick:
flamin mongrel!!! It certainly idles and revs over 2500rpm but I haven't driven it yet...
and actually no. Despite the fact my bonnet is currently open and has been all day, I've only been fiddling in the boot and mostly the passengers footwell. :) was under Rosie's Bonnet though.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
