I might take a drive out there but I cant until after lunch.
Anyone else still going to be there?
I'll hang round for a while, likely get there 12 -1 at this lazy rate. :)
and Yay for welding!
Haha sounds like it also boost drop.
If you can mark out the holes I should be able to weld it up. Wont be pretty though
Hahaha won't be Scotty pretty?
JEZ welded this at like 7pm on a Sunday night
So it's already an abomination.
Should I try the stuff from rep co or just come see you?
Thanks for coming out guys. :D
Good fun, its like an old mans motorsport, relaxed, freindly, a great way to get into motorsport.
Did 4 laps today
CAR 26
Skyline
62.96 3.32 16.38
58.58 3.22 15.26
57.69 3.36 15.53
56.48 3.12 14.58
55.48 3.15 14.42
54.66 3.32 14.57
Very happy with cutting time each lap. first lap ever 63 sec, down to 54.66 by the last. sweeeet.
Now i see the limits of my diff :down: too much wheelspin. But its interesting trying to drive it properly and overcome some of that.
post-89755-0-08620500-1376203301_thumb.jpgpost-89755-0-79190900-1376203327_thumb.jpgpost-89755-0-44537800-1376203346_thumb.jpg
post-89755-0-38930600-1376203369_thumb.jpgpost-89755-0-97798500-1376203393_thumb.jpgpost-89755-0-72538100-1376203418_thumb.jpg
post-89755-0-29602000-1376203437_thumb.jpgpost-89755-0-58536500-1376203453_thumb.jpgpost-89755-0-42797700-1376203469_thumb.jpg
And that last shot is just for love. :wub:
Edited by D.I.Y. Mik
    • Before starting any work, we attempted to adjust the tune. However even after adjusting it to certain extremes like completely stopping fuel, it had no effect. What fixed it was removing the Nistune Board and installing the original EPROM instead. This immediately fixed the issue. Everything should have been fine with the Nistune Board installation, so I am unsure why it has caused a problem. The soldered connector is also properly soldered. This worked when I first got the 550cc injectors, before cleaning, but that may have been a coincidence.  We ended up not installing the fuel pump hanger (at least for now). So currently running stock injectors, stock fuel pump, stock fuel pump hanger – Well everything stock except the exhaust. Now I have around €1400 in Nistune, Injectors, and Hanger collecting dust for the time being, perhaps I'll install them in the future. For now I'll enjoy the car as is 😁 Thanks a lot for all your assistance, I really appreciate all the help you have given me.
    • The turbo can’t be the issue. They’re proven to make much much power than you’re making. There is something in the setup that isn’t correct. - has the exhaust got any silly step downs? - what exhaust manifold?
    • Ok, just the way you wrote it made it look like you had the stagger the wrong way around
    • I was getting anxious with the DVLA not knowing if the paperwork is fine or not, so I rang them. No update had been given, but I  was reassured that providing the box was ticked on the V750 then the application will go through fine. I've been checking the DVLA website pretty much every day, in the hope that it would have been done. Fast forward to Monday 29th  and I was greeted with a new screen on the check, and it finally showed as Taxed and MOT'd, woohoo! The car was in desperate need of a clean, not knowing when this day was coming it was put off. As far as I was concerned I had another 3 weeks  I'm not normally one for using snow foam, but I wanted to give it another try It hasn't cleaned up too bad considering it's 21 years old and lived on a boat for a number of weeks. The personalised number plate is J2 XBK, an illegally spaced number plate would have it read J2X BK. BK could either represent  the colour black or Baker, which is my surname. I filmed the first drive, the Youtube link will be at the end. I used the same driving route I did with the 323F V6 when I had a new exhaust installed, heres a couple of photos A few more since then Youtube video can be viewed here: https://www.youtube.com/watch?v=TjkFHPzjGDw
