No more leaking from the 2 welds.
Haven't started it up yet though.
Tomorrow will tell
Sure you don't need to do a quick run to the shops for something???
I think you do... :woot:
I surely will soon enough....I finished running in the new motor for the ute today so getting her running is now #1 job.
Plus, I thought SDMA was great fun.
Most excellent, be sure to bring me my seat....err....beer
Just updated my build thread.
Check it out if you are interested guys
http://www.skylinesaustralia.com/forums/topic/429635-manuel-kasko-33-buildjourney/
Nice!
One of the Cops in that Vid is BRAX from Homo & Gay Home & Away.
He's Dreamy... ;)
:unsure:
Is he one of the guys in the ads with the ghey Bra Boys neck tats?
If so, I'm so going to watch that clip... totes dreamy :wub:
