No passengers .
Ive never seen a big stack at sdma
Just be sensible and youll be fine.
Ye dunc frustrating but better than nothing
SDMA can kill.
It's the track that turned my uncle into a Quadroplegic.
Yeah its got trees and a gully near an off camber blind corner etc...
Definatly have to drive safe there. Im not game to go hard on the downhill bit
or the corner before it
225s rob, got em
Edited by D.I.Y. Mik
:O Oh...
Nasty. Sorry to hear that.
Yeah, happened many many many years ago, and to one of the people they least expected it to happen to as well. He was massively into safety with CAMS, and one of the best drivers of his time. Held a few out right records from 3 categories down when he crashed from what I can remember being told.
please explain what a sexy penis is....
If you don't know then you don't have one..... ;)
ok, the penis in question was attached to a grotty man, tied by rope to horse, and he had to keep walking till he died. So not very sexy.
As opposed to one being used in a..... ermm.... sexy manner :D
Damn...I guess I will have to withdraw from the sexy penis of the year awards. : )
Sorry to hear that matty. Didnt think that was sdma.
I always maintain that if you enter a car in any motor sports event you must be 100% prepared to bin the car.
Now I dont mean drive 11/10ths everywhere. I mean if you absolutely need the car for work or can't afford to fix it thN dont enter.
Ive seen it too many times where someone has a blow or a stack then sooks about about not having a way to get to work.
But reality of it is you are safer at sdma than going for a fang up cotter rd
It's fine... lol. Guess it depends what your definition of "fine" is for children's viewing.
True, but I wouldn't class a 15 year old a child, more a teenager. To which, they've probably done, seen and or thought about everything in an episode of GoT. But than again, I'm not a parent so my say is inavlid regardless.
Edited by RosieR34
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
