Yeah always had a soft spot since he got one and yeah his is black but hasnt been on the road for over a year... And there is always the itch to hear vtec kick in right behind your ears.....post-100668-13769932567054_thumb.jpg
So am thinking of buying a single piece front/dump pipe. Anyone have experience installing this without a car hoist? I figure its possible just with stands but have a feeling this could be a bitch?
I got a Just Jap Stainless Bellmouth, got it installed as I REALLY didn't want to deal with Snapped Bolts and Studs in the Turbo etc...
It needed a bit of tweaking of the Flange *giggles* to get it to fit. (apparently china pipes are like that)...
Was quoted $120 at Roadway Exhaust in Belco and $150 at Trojan. Trojan won. They replaced all bolts with studs and use Genuine Gaskets.
(not those Crappy silver ones with holes in them)
I have pulled my Frontpipe of before using axle stands etc... It's fiddly under there but as long as everything lines up and nothing breaks. You may be lucky.
  • Like 1
Yeah always had a soft spot since he got one and yeah his is black but hasnt been on the road for over a year... And there is always the itch to hear vtec kick in right behind your ears.....attachicon.gifImageUploadedBySAU Community1376993228.584755.jpg
haha is it parked there cos it won't make it up that driveway?
Yeah seriously some people are f**king RETARDS on that page. Some of them don't even post text with the pictures....it's like cool story bro nice pics, but what in the actual f**k was the point to posting them? Oh, you want to sell something? Well, what? The wheels? The panels? The whole thing? You DON'T want to consider swaps? Here, I'll give you $5. You're offended at my stupid offer?? Well what the f**k did you expect?
/raaaaaaaaaaaage
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
