Yeah I love those wheels.. If they were 1800 I might consider it in the future.. But all the ones I can find are around 3 grand lol... Far to expensive for my liking :(
yahoo auctions or Ebay. I got my nismos for $2200 with RSR semi slicks on them. Being ready is the thing, coz you'll run into a steal price whilst your broke as f*ck
Haha yep, have noticed that.. Murphy's law aye :/
yeah i ordered mine directly from work japan when the aus dollar was worth 100 yen. but if you go through jesse streeter and keep an eye out on yahoo auctions its possible to get a set for a decent price.
:/ cracked head ! - sorry man
shouldn't take as long as it has to buy one, fully service, bolt back on.
Hope that is all and there is nothing more......
You haven't even really run it in since rebuild. No wonder your cranky.
There have been a few delays. One of them was Nengun sent me the wrong cams :angry:. Now im waiting for parts again as im giving her a facelift... Will post pics when i get it back lol. I spoke to Ultimate today and they are expecting it to be done next week. Fingers crossed.
Stoopid mistake today
Came out of the servo and had to accelerate quickly to make the lights and avoid the cars coming up from behind.
Tramped it and got to the end of the rev range,,,,, went to change up gears,,,,, foot on clutch, grabbed gear stick to go up a gear ............................
car braked hard so suddenly during the quick shifting nearly smacked the windscreen with my head
That's when I realised - I'm in the freakin 34 - it's AUTO.
...(pushed hard on brake peddle thinking clutch - DOH !)
In all honesty, Having VERY LIMITED Auto Experience, I have done the same thing.
Scarey as all f**k and Extremely Embarrassing. :blush:
Although now with driving the Forklift at work, I have gotten use to the Auto and Braking with the left foot.
Would've been funny to see :P I'm actually really surprised I've never managed that tbh. I've GONE to do it countless times, but seems instinct kicks in when there's nothing below my foot where I expect there to be something, so the whole movement just ends up as a bit of a spasm most of the time lol
I had a serious accident because of that coming from Melbourne middle of nowhere. The car had a pedal handbrake sorta like a clutch on a manual. So going uphill I tired downshifting and booom sudden stop and the car behind me raped the rear end.
They should not make handbrakes like that no wonder you can never use that sort of car for a driving test.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
