Other than the fact it's under finance, that's what I love about the van - ridiculously good on fuel (~1000km from ~57L), can carry heaps of shit and you can sleep in it.
Shame about the expensive part haha
yeah that is frustrating. I can connect the Leaf but neither the Cube nor Cima work, they must be too old for ODB2. PITA
Speaking of the Cima it finally arrived on the weekend, drove it down today (goes great, it's like cruising on a lounge chair).
cima.jpg.
But...there are 2 problems:
* check engine light is on (goes fine though)
* front brakes need machining
Is there a workshop in Canberra who aren't afraid of imports and have a consult 3 or similar tool that can turn the light off, and can machine discs? I'd prefer to get both sorted this week if possible.
Is it just me or do you have your lefts and rights confused. :D
Consult (Grey Plug)
My Bluetooth adapter is OBD and with an adapter cable will plug into my Consult port but won't connect.
It would be worth a phonecall... I've only dealt with National Capital Motors in Belconnen (mostly for Parts) but they do have a service center there too.
I should imagine they would have the appropriate Technology. :)
all sorted now, turns out a lot of the Nissan dealers think they can't do imports :blink:
just got a local guy back home to do the discs and turn the light out at the same time. it was an AFM warning but I am 99% sure it was only because I unplugged it while f**king around with the headlights
BTW is it me or did winter just start again?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
