So after Richard kindly lending me his trolley jack and just finishing reading a couple tutorials I have officially chickened out of doing my own brakes!
It seems there can be issues getting things on and off due to age etc. and I am not very well equipped here to deal with anything unforeseen that comes up.
Looks like its off to the shop for me. : ( LOL
Not sure Mik. Tutorials were saying that the discs could be fused to the hubs etc.
When I did mine, there was a threaded hole in the rotor that you put a matching bolt in and tighten, it pushes the rotor away from the hub. I can't remember but I think all 4 rotors had the hole. Made removal quite easy.
This was instead of using a rubber mallet.
Just smash em off. :D
Might pop over some stage during the day, will see how we go.
What do people use for diff and gearbox oils..? Thinking of changing mine tomorrow. Seen a lot of people recommending Redline, on the forums, though it looks like that won't be too easy to get my hands on for the time being?
NULON.
Made my gearbox and diff feel like new.
I also use Nulon for the Engine, All Very Smooth.
I have a little hand pump you can borrow if needed.
Make sure you can undo the filler plug BEFORE you undo the drain plug. ;)
I use motul gear 300 in my box. It's expensive but cleared my synchro issue right up and shifting feels great now. I also ran it in my diff as it's a viscous still so i didn't t need any lsd additives in it.
  • Like 1
Just be a bit careful with that. I've been a redline user for years including in the race car and have been very happy (in particular it hid gearbox issues like crunchy synchros). However, a couple of years back they changed the formula to remove something bad (carcinogenic) and it has never been the same since. The main issue is it expands heaps when hot (which happens a lot in a race car) and so it comes out the gearbox breather...literally litres of it.
I've used and was happy with the royal purple gearbox/diff oil for racing, but I would probably stick for motul for hard street use, or anything for light street use. Nulon has a good rep too but I haven't used it
  • Like 1
Yeah, mine were just a bit warped, a little surface rust underneath, but not much.
Putting the wheels on and off is half the job, have a go!
And if they are fused so bad we cant get em off, just put the wheels back on and take it to a shop.
BIG jack, breaker bar, tourque wrench, rattle gun, etc.. got these if you guys need em.
    • Before starting any work, we attempted to adjust the tune. However even after adjusting it to certain extremes like completely stopping fuel, it had no effect. What fixed it was removing the Nistune Board and installing the original EPROM instead. This immediately fixed the issue. Everything should have been fine with the Nistune Board installation, so I am unsure why it has caused a problem. The soldered connector is also properly soldered. This worked when I first got the 550cc injectors, before cleaning, but that may have been a coincidence.  We ended up not installing the fuel pump hanger (at least for now). So currently running stock injectors, stock fuel pump, stock fuel pump hanger – Well everything stock except the exhaust. Now I have around €1400 in Nistune, Injectors, and Hanger collecting dust for the time being, perhaps I'll install them in the future. For now I'll enjoy the car as is 😁 Thanks a lot for all your assistance, I really appreciate all the help you have given me.
    • The turbo can’t be the issue. They’re proven to make much much power than you’re making. There is something in the setup that isn’t correct. - has the exhaust got any silly step downs? - what exhaust manifold?
    • Ok, just the way you wrote it made it look like you had the stagger the wrong way around
    • I was getting anxious with the DVLA not knowing if the paperwork is fine or not, so I rang them. No update had been given, but I  was reassured that providing the box was ticked on the V750 then the application will go through fine. I've been checking the DVLA website pretty much every day, in the hope that it would have been done. Fast forward to Monday 29th  and I was greeted with a new screen on the check, and it finally showed as Taxed and MOT'd, woohoo! The car was in desperate need of a clean, not knowing when this day was coming it was put off. As far as I was concerned I had another 3 weeks  I'm not normally one for using snow foam, but I wanted to give it another try It hasn't cleaned up too bad considering it's 21 years old and lived on a boat for a number of weeks. The personalised number plate is J2 XBK, an illegally spaced number plate would have it read J2X BK. BK could either represent  the colour black or Baker, which is my surname. I filmed the first drive, the Youtube link will be at the end. I used the same driving route I did with the 323F V6 when I had a new exhaust installed, heres a couple of photos A few more since then Youtube video can be viewed here: https://www.youtube.com/watch?v=TjkFHPzjGDw
