Atleast we speak the same language now Daniel parts can be swapped and shit if something goes wrong and you dont know what it is.
S1 or S2? with series two you gotta put down your clutch to start it which is kinda cool coz modern cars are doing it now but nissan had already thought of that 1998
Really? I didn't know that. Why is that a good thing?
Congrats Mani! Those 12 weeks are gonna take foooooooorever!! :P
That Clutch in to start function sux balls... You can't just lean in, knock it into neutral and start it. Must be in the seat.
Hyundai have been doing that for probably 20 years. (found that out when a friend couldn't start her old Excel)
  • Like 1
I clutch in before I start my r33 anyways haha
Must be a habit I picked up from somewhere.
Could possibly be that I tried to turn the key a few times when it was in first and I didn't clutch in.
The car is a series 2 so that's why it has thy funky looking front bar haha. But they do come with a better diff so that's an added bonus.
Thanks for the offer with part swaps Bryce and Shell you are right about how it's going to feel like a life time before the car arrives.
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
