Yep pull it all off.
There are 14 or 15mm nuts under the dome cap thingos at the base of the arms.
Pop them off. Undo nut. Wiggle jiggle the arms. Spring makes it tricky. Remove, sand, paint, rejoice. :)
  • Like 1
Doh :(
It's ok, had some guy in a wrx wagon behind me. Pulled over at that truck stop and we had a chat for 10 minutes. Beautiful car :)
Was good run though, heaps of traffic out today
Gotta love car people. Always that common interest :D
I've got both. :D
and yes I've spent many a time searching thru rocks, sticks, leaves and dirt trying to find that screw that parted ways from my RC and ruined my fun. :/
Sir Son of Rajab Van Von Vader'ham. :laugh: Pricless.
it wasn't screws that I hated with using the truck offroad, I did loose heaps tho, it was the flat out sideways into a tree stump that got me! wasn't noticed when I had a look, using it without the body or bull bar, ripped the whole left hand front wheel and suspension off, then lost the dog bone for the 4wd.. cost like 400 in parts, then I put it all back together, in 2wd with a huge motor it was so fun! it lifted the front wheels up and flogged my mates vl ( in hume ) before he crashed into a tree in his street :D haha thats vl drivers for you :) then having it flat out for a long time running to lean just completely rooted the engine :( and went to get an engine the other day and they dint sell ones with a rotary carbie :( so its in now in a box in the garage :(
Yuh huh, cool story. :wacko:
So what are you all up to in your final minutes of 2013?
I have a belly full of Aldi Beer. Might just crack me a bago chippies. :D
haha, having some mountain dew, yea im that kind of guy ;) nah going for a drive down to banks to pick the sister up from a party, ahah
starting the year driving the skyline - going to be a good year :D
Looking for some info on how to install a plenum on an RB26DETT. I have found heaps of info for the RB25's but nothing for the GTR's.
Currently searching YouTube as well.
I have Richard's old polished plenum sitting here which I have had for ages so thinking I might give it a go depending on how involved it is.
Morning.... i see whos up early too. :happy:
Mine was up at 5:45.
Anyway, id look at how long all hoses and things are and if they will reach the new location.
Also the ends of them have to fit the fittings on the plenum.
Throttle cable too. TPS would need a wiring extension. And intercooler pipe with a bov and return line for that.
Hang on... RB26 has throttle bodies.. so.. um... dunno. Id have to look.
New gaskets would be a good idea
Im just assuming its forward facing... is it?
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
