Cool. Any idea the best place to get one? Closed my door when I got home and the window exploded!
That is Crazy! Do you think it was touching something hard inside the door?
or maybe too much air pressure inside... Seals too good.
Trojan? or whatever JapSpec turned into?
or Try Jap Parts in Fyshwick maybe...
Damian 0449775209 -
Ph: 6280 0606
Ah: 6280 8898
Tell him Rob with the R31 Wagon sent ya! :thumbsup:
hmm that is strange....I agree it seems likely it either hit something inside or maybe the lower seal is rusted/loose?
anyway, if you find a window in Sydney I can bring it down next week.
Bub wanted to get up at 5 this morning.....
Lucky he did, i found water spreading across the lino floor.
One of the fishtanks is leaking. Emptied it out, fish in a bucket, took it outside.
Good excuse to get rid of it...... dont tell the missus i said that. ;)
less fish time=more skyline time
Anyone want a pair of Angelfish?
Edited by D.I.Y. Mik
I once had an old Pintara as a daily that someone smashed the window on. We got the window from the wreckers and I can't remember it taking Pete more than a couple of hours all up to fix?
Different car but still Nissan with all electric bits etc.
Surprised also if there's not a tutorial on here how to do it somewhere.
Hi Eric - have done it twice on my 32
It's not complex at all but the first time will take 1-2hrs. It's mainly about the angle of getting glass out/in.
Make certain you give it a great vacuum if the glass has shattered.
It gets every where but particularly on the brushes and inner/outer window strips
Which means if you don't do it properly your new (2nd hand) window will scratch-up the first time you put it up/down.
It's 10 minst to get the door card off and all the window switches out and unplugged
bout 10-20 to undo the nuts holding the window in
bout 10-20mins removing the window - but if yours is shattered just the thourough vacuum and removal of broken glass.
I did it alone but it would be a lot easier if there are 2 of you. Just balancing the window, slotting it in and doing the nuts up whilst the other holds the galss in place.
TFE mate.
$150 for a window and $300 to install it.
How hard are they to install? Anyone have any idea?
Cheers.
It wont be too hard would just need 2 sets of hands to do it.
I might be able to assist tomorrow night if you need
yeah DIY is very do-able, cleaning it out is the pain as said above. Also check for rust in the channel that holds the window, and also rust or damage to the "waist mould" that goes along the top of the door.
the only other issue can be adjusting the window afterwards (we had heaps of trouble in the 350z) but I think a 33 should be old enough to just do a straight replacement without any annoying adjustments.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
