who's doing it Eric?
Always good to know who will polish stuff :yes:
A friend Dan. He is a car detailer and is also doing metal polishing as well. He did someones turbo recently and it came up like a mirror.
He also polished and sealed my headlights. He did someone else's on here too but can't remember who it was.
If you want his details let me know.
Any one got access to a Ball joint Press?
probably, but not exactly sure what you need.
do you need to separate a ball joint from some sort of rod end, or do you need to press a ball joint out of a control arm.
if it's number 1 I can bring one down tomorrow, if its number 2 I could do it over the weekend (but I guess you could get any local shop to do it too)
Number 2. Press out and Press in Newies in the 31. I'll likely just get Pedders to do it but I'm replacing all the Bushes in the 31 aswell.
By the time I take it to them I'm hoping to get all Bushes done and Reduce their quote from over $500 down to about $50. :D
DIY FTW! :D
yeah I much prefer doing everything I can.....at least that way if a mistake happens I only have me to blame.
I've had too many bad experiences with shops over the years, they all make mistakes, and some of them are really f**king rude when they do.
you are doing this job right? https://www.youtube.com/watch?v=pOLVV7HYkZs. I'd take it to a mechanical workshop rather than pedders personally....like I said, if you get stuck I can bring it back and do it next weekend but a press is a pretty common tool.
I recently did all the bushes on the ute, the only ones that were really an issue were the front LCA inner bushes in the chassis, they were an arsehole to remove....couldn't press them out with a g-clamp (saw your cool tool :thumbsup: ), ended up burning and recipro sawing them out.
Yep, just like in that vid. And yeah I was considering using a Regular mechanic but thought Pedders being all about suspension etc could do the balljoints while they do the bushes.
Having had some good success with the LCA bushes, I'll have a crack at the Upper and lower trailing arm bushes and pan hard rod.
If successful, I'll just need to get Ball joints done somewhere.
Save a buck and learn a heap! Lovin' it. ;)
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
