I dont know a lot about it but from what I knows I'm not interested in it.
Too few pumps, big dollars to set up, less millage.
I like the idea of cruises and I feel it will limit that and cost more.
But like I said I Dom know a lot about it, might try find a doco
E85 is for the weekend warriors! Premium is for us daily drivers :P
Even though mine isn't a daily, 98 is for me, also my boss pays for it :)
Full flex tune :)
E85 on the weekend and 98 mid week
I have seen these flex tunes, does it run 100℅ on either, or is it like the old gas tunes where it runs better on one? Does the tank need to be nearly empty to swap between them?
Nothing wrong with using E85 Daily. Unless you are running turbos larger than -5's Judd it isn't worth the upgrade though.
I will never run bigger then -5s even -7s would make me chub up enough. I have a mate with an SS on OEM e85, too little servos, it just seems inconvenient to me....unless its a dyno queen. But that's a whole different gear grinding story lol Edited by gtr judd
Full flex means you can run any mixture and it's the best way to go. Price for the tune works out to be double a normal tune so around $1500 but then all you need is a capable ECU and a fuel sensor.
It will of course run quicker on e85 but when running straight 98 it will run just as good as a normal 98 tune because it has the fuel sensor and adjusts the map to suit
  • Like 1
Is a loverly looking Beast. ;)
I Finally got me a decent Camera today thanks to Ebay.
Gone from a 4mp Sony point n shoot to a 12mp Pentax DSLR. 300mm Zoom is also in the Post.
Yay. :bunny: about time.
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
    • This is what the look like normally. Except we only got the 2 doors locally
    • Back pressure is not really a function of the exhaust itself, but the turbine/housing. So the question/point remains valid. I would be fitting an EMAP tapping point and seeing what is going on in the exhaust manifold before committing to throwing boost at it. Flow. No intercooler is actually rated for continuous operation at any power level wrt temperatures, as they are no actually capable of shifting the required amounts of heat on a continuous basis. They get hot during a pul, then dump some of that heat into the external air (and some back into the internal air) during off load moments/periods). You probaby do need a bigger core, given the power level you're already at is somewhat above the "rating" of the cooler. Put pressure tapping points either side of the core (which possibly you already have, if you have a boost source near the compressor outlet and tapping near the throttle for existing purposes) and report on delta P across the core.   I haven't done the mass flow calculation to see where you would be sitting on the compressor map at the ~450is rwkW level we're talking here, but if you look just at the PR you're running at, which is ~2.8-2.9, then you have a really really wide swath of the compressor map to run in, and so long as you were making between about 45-75 lb/min of flow, you should have really good comp efficiency, with the ideal being betweem 55 and 65. I can't see the need to shift drastically on the map to get better results.
    • Welcome 🙂 The ER34 wheels and slight lowering suit the R33 sedan really well. I'm firmly in the 'keep it stock, at least on the outside' camp.
