Haha I found one before and he fixed it straight away. Just sent him your one as well.
When I get back we are going to do a full detail on both of my cars and his going to write a blog post on the website called "Old meets new"
He recently won best Maserati at that Italian auto show on parliament grounds.
Pretty glad I don't post in normal wasteland anymore. Just checked out some kids build thread where all those guys were being dicks and then the mods come in and join in with filling his build thread full of shit.
The kid clearly had it coming but honestly a build thread is not the wasteland.
Yep, I just read thru the whole thread. Mostly just pricks being dicks.
He has some interesting taste in mods (Not My Cuppa) but it is HIS Taste so leave him to it I says.
After all, It is His build thread. Each to their own.
It's no wonder some longterm SAU people have a tendancy to distance themselves from it from time to time. :/
Yeah well that's the worst part of it. The guy is now never going to share his ideas or experiences again.
I love this club and I love the fact we have so many different people throwing together so many different setups. But the fact that even the mods joined in to create a wasteland of his thread is just disappointing.
I mean sex spec or what ever you want to call it is not for everyone. But it's his pride and joy which just got smashed to bits on a public forum. Also the fact he wasn't one of those guys who just joined and started to be a dick.
I'm sure threads have been cleaned up and warnings handed out for much less.
Constructive criticism is fine but there isn't much of it there. Just negative dribble and unrelated crapus.
It is disappointing.
It's in the wasteland? Well there's his first mistake... no one takes things seriously in there. I can't remember the last time I even looked in that section lol. I like off topic on forums but the wasteland is just shit.
Thanks for mentioning the thread guys, it was bullshit. Cleaned up now but it should never have had that much crap for so long.
Generally...if someone sees a thread that needs cleaning up please report it. I can't speak for all mods but I for sure don't have time to actively moderate every thread, especially ones that I am not officially a mod for.
  • Like 1
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
