Thanks for sorting it out Duncan!
I think the community definitely still has value but sometimes things like that just go too far.
Hopefully the guy hangs around and shares his build with us. It's not everyone's cup of tea but there are people out there who would enjoy what his doing.
  • Like 1
Bought a chemistry set from China, to do some food experiments.
Anyway, because im not into amphetamines and such, i didnt realize its the kind of thing they use to make it.
The police told me they do.
When they Knocked on my door this morning and asked what its for.
:O
I dont want do have anything to do with that sht.
Now they will use it for a display set for education purposes.
I investigated the legality of alcohol distillation and Nicotine for E cigarettes, but not the glassware.
I just didnt realize or think it through, i dont know if its my fault or not. But i feel stupid.
Oh well sht happens. :blush:
  • Like 1
Its funny, but i didnt really look at their ID, you know in a bit of shock and all that.
I just found out it wasnt the drug squad, who was it then? interesting...........
But i know its legit otherwise they wouldnt know i had it.
Maybe people are keeping an eye on me, i know too much about how to make the wrong things cos my dad was a rocket scientist.
Edited by D.I.Y. Mik
Cool....
I actually wanted to try and capture the aromas from freshly ground coffee, by freezing everything, including the glassware, grind the coffee, put it in the first chamber by itself or with ice water, then gradually bring it up to 25-30c, distill it through a Vigreaux column to concentrate it, and try to condense the aromas again possibly id have to use Nitrogen to get cold enough.
The elusive essence of coffee, but it has to be stored cryogenically.
Then theres chocolate, i wonder if you could get an aroma thats like the taste of chocolate, not the usual smell you get.
Or an essence of full on choc flavour to add to things.
And all the other things, just use your imagination, what would be awesome?, try and make it.
Cool....
Haha I don't think the popo are stalking you on SAU :P
Everything that comes from overseas is marked and tagged. Suspicious and all that get headed up to the Police. It was probably the Feds just doing their Wednesday postal investigation run. You'll be fine! Just don't buy another one haha
edit: 1 member, 1 guest. FEDS ARE HERE! :P
Edited by RosieR34
Been doing some research, it seems that drug makers use jam jars and garbage bin lids etc to make drugs.
Not lab glassware. I feel ripped off.
Did some inquiring today and it seems these guys are mystery men. :ph34r: Not with the normal police, i dont know who they are.
WTF? :O
Anyway with some luck ill get it back and make incredible real deal coffee ice cream.
I think id have a batch perfected before summer comes around.
People like to kill my dreams........ :(
Hey chaps and lady chaps
http://www.skylinesaustralia.com/forums/topic/444079-s-a-u-celebrates-r32-g-t-r-25th-anniversary/#entry7304362
R32 GTR 25th Anniversary coming up in August
Check it out
Will be Epic!
Check it out
Will be Epic!
Wow looks like a big event!
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
