Anyone know a good place to buy some Michelin (265)/(275)/35/18. Under $650 for a pair or AD08 or something close excluding federals as theyre a nightmare in the rain.
I got a good price online from Ozzy tyres for my Michelin Pilot Supersports and so far I think they're a fantastic tyre.
A 265/35/18 was around $1600 for 4 including sending to Canberra. Wasn't much difference in their price compared to tire rack after you factor shipping, customs and quarantine fees etc.
  • Like 1
"How much were they for the set, if you don't mind me asking?"
I did some hunting around in the end Bob Jane at Fyshwick were the best at $1340 all up, as I said I'm very happy with them.
Edited by THE34T
You have the RSR yeah Richard?
I'm running just the standard 595's and I think my camber probably pays a good part in shit traction.
Best thing about them though is that they hold well in the dry and they have lasted me for nearly 2 years!
Im running the RSR dan and i can't fault them. Even in the wet.
Okay folks.
It is going to be an absolute nightmare financially and physically to get the 34 registered in Victoria so I think I am just going to sell it real cheap to someone in the ACT if they want it. We only really need one car here in Melbourne anyway. What do GTT's go for these days?
I do like having fresh breth though.
The issue with rego was that i just wanted it in Vic rego so it would be easier to sell.
I was initially told that if it was an interstate car with current rego i don't need an inspection, i just need an appointment to hand in plates and they would honour my rego. Today i find out that because it was an import never registerd in vic they dont have my compliance plate on record so it will need to be a full rego inspection and ID check, which i would fail because i am in no position to spend money putting my car back to stock just to get it into another state just to make selling it easier.
I will just leave it in ACT rego and sell it cheap enough to sell it quick but still not make a massive loss.
I barely drive it here in melbourne so it's just dead money really...still...it will be sad.
Also selling mine Andy ( can't plug it enuff :P)
http://www.carsales.com.au/private/details/Nissan-Skyline-2001/SSE-AD-2909440
Do a search on carsales anywhere from $7k to a very hopefull $25k
Mine sits squarely in the middle ground (also known as the kill zone !)
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
    • This is what the look like normally. Except we only got the 2 doors locally
    • Back pressure is not really a function of the exhaust itself, but the turbine/housing. So the question/point remains valid. I would be fitting an EMAP tapping point and seeing what is going on in the exhaust manifold before committing to throwing boost at it. Flow. No intercooler is actually rated for continuous operation at any power level wrt temperatures, as they are no actually capable of shifting the required amounts of heat on a continuous basis. They get hot during a pul, then dump some of that heat into the external air (and some back into the internal air) during off load moments/periods). You probaby do need a bigger core, given the power level you're already at is somewhat above the "rating" of the cooler. Put pressure tapping points either side of the core (which possibly you already have, if you have a boost source near the compressor outlet and tapping near the throttle for existing purposes) and report on delta P across the core.   I haven't done the mass flow calculation to see where you would be sitting on the compressor map at the ~450is rwkW level we're talking here, but if you look just at the PR you're running at, which is ~2.8-2.9, then you have a really really wide swath of the compressor map to run in, and so long as you were making between about 45-75 lb/min of flow, you should have really good comp efficiency, with the ideal being betweem 55 and 65. I can't see the need to shift drastically on the map to get better results.
    • Welcome 🙂 The ER34 wheels and slight lowering suit the R33 sedan really well. I'm firmly in the 'keep it stock, at least on the outside' camp.
