Ask Chris at inline, he has my old triton ute with 8 inch wheels. I put them on with nothing done to the suspension, Going from stock skinny ute wheels, and it was a huge difference. In a bad way. You have to really hold onto the steering wheel, or its all over the place.
My Volks are wider than the gtst wheels and i can feel it with them as well, but not as bad as the old ute.
Because ive got adjusty bits i have compensated a little, but it will affect other stuff if i go too far.
Fine tuning the camber and castor helps. But it takes ages of fiddling around, and you really have to diy because most suspension shops wont be that specific.
And say you did go to inline with exact specs, you need to measure it very carefully to get those specs, so you might as well diy while your at it.
So....
Its actually very easy, just time consuming. Youtube taught me how to do it. If your careful it will be very accurate.
You only need: A ruler, a level, a piece of string, a pencil and paper for maths. Some fancy angle measuring devices allow you to skip some of the maths.
To get the car perfectly level, you need, some vynil tiles, clear tubing, a bucket of water, and a ruler.
Dont give up on the beast, it just needs the right touch. :thumbsup:
  • Like 1
If Inline and Capital S+S cant find and fix it then thro car away - It's bent !
No Richard I'm not throwing it away :no: .. it's not bent, I've had the car for 5 years and have only had the problem for about 18 months and twelve months of that I hardly drove it, had a company car etc.
So, I'm at the point of either 250-300kW or doing cosmetic changes.
I've spoken to a few people and getting mixed thoughts. I'm siding with cosmetic for the time being.
Option 1-Cosmetic:
1.CF Boot lid:
2.Top CF vented bonnet:
R34GTT_Nismo_Bonnet_Chipped_01-500x500-5
3.CF mirrors:
4 a few touch up paint work on a few chips.
5. SAFC setup
Option 2- Power:
98
highflow/big turbz
nistune
+supporting mods.
Now, I'm siding with the cosmetic with a SAFC piggyback given that my mirrors are absolutely shot and need to be repainted (replaced with CF mirrors in this case). Bonnet has a few marks and well, the boot is a nice touch to it. I'll be going wingless and that's pretty much about it. Cons for Cosmetic is that the car does live outside :(
And, one day when I do finally upgrade to a GTR the mirrors and boot lid can come across with me
Power:
No real pros except for... the thrill of acceleration (My ultimate joy).
Cons would be more things to break, more fuel usage etc.
Anyone with their 2cents of experience?
Edited by RosieR34
Thanks for the input everyone, I really didn't mean to cause such a fuss :wacko:
During the past 6 months of trying to rectify this I was amazed by one thing, both Chris at Inline and Capital S + S told me that the brand of tyre can make a huge difference. When I had this proved to me and I changed all tyres from Pirelli to Yokohama it was an amazing difference, like a different car. So with the trye change I came from a huge problem to a minimal one, I think from here it's in the 'fine tuning' as Mik suggested.
So like the lady she is I'll continue to fiddle with her, treat her kindly, service her regularly and give her a good hard drive every now and again, and life will be good.
Thanks to one and all ... :thumbsup:
  • Like 2
Option 1-Cosmetic:
1.CF Boot lid:
3.CF mirrors:
5. SAFC setup
Option 2- Power:
98
highflow/big turbz
nistune
+supporting mods.
Power:
Don't bother with the SAFC imo.
Only something you will need to replace down the track
If you don't want to change the turbo etc
than Nistune is a good option to make the car drive much nicer, have more power, and better economy without needing to change turbos/injectors etc
As for the carbon bits.....it just screams "defect me"
  • Like 1
Option 1-Cosmetic:
1.CF Boot lid:
3.CF mirrors:
5. SAFC setup
Option 2- Power:
98
highflow/big turbz
nistune
+supporting mods.
Power:
if it lives outside don't get anything CF. CF gets damaged by the sun really badly. you will have to coat it alllll the time. Also what zeb said.
Speaking of Nistune, who does it locally? or should I say, who should we go to locally to get this done?
Only choice is Ed at Autotech in hume.
He did mine and got 245rwkw with Nistune
will need a few extra bits (like injectors + Fuel Pump)
Edited by Sinista32
hmmm worse than red? :'( man that sucks. Was getting a tad excited.
Might just get the mirrors and some power
Jeremy, excitement is in the eye of the beholder .... fast mirrors are always cool and a little 'classy' and power will give you that warm an fuzzy feeling inside, power is the gift that keeps on giving. :closedeyes:
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
