Ask Chris at inline, he has my old triton ute with 8 inch wheels. I put them on with nothing done to the suspension, Going from stock skinny ute wheels, and it was a huge difference. In a bad way. You have to really hold onto the steering wheel, or its all over the place.
My Volks are wider than the gtst wheels and i can feel it with them as well, but not as bad as the old ute.
Because ive got adjusty bits i have compensated a little, but it will affect other stuff if i go too far.
Fine tuning the camber and castor helps. But it takes ages of fiddling around, and you really have to diy because most suspension shops wont be that specific.
And say you did go to inline with exact specs, you need to measure it very carefully to get those specs, so you might as well diy while your at it.
So....
Its actually very easy, just time consuming. Youtube taught me how to do it. If your careful it will be very accurate.
You only need: A ruler, a level, a piece of string, a pencil and paper for maths. Some fancy angle measuring devices allow you to skip some of the maths.
To get the car perfectly level, you need, some vynil tiles, clear tubing, a bucket of water, and a ruler.
Dont give up on the beast, it just needs the right touch. :thumbsup:
  • Like 1
If Inline and Capital S+S cant find and fix it then thro car away - It's bent !
No Richard I'm not throwing it away :no: .. it's not bent, I've had the car for 5 years and have only had the problem for about 18 months and twelve months of that I hardly drove it, had a company car etc.
So, I'm at the point of either 250-300kW or doing cosmetic changes.
I've spoken to a few people and getting mixed thoughts. I'm siding with cosmetic for the time being.
Option 1-Cosmetic:
1.CF Boot lid:
2.Top CF vented bonnet:
R34GTT_Nismo_Bonnet_Chipped_01-500x500-5
3.CF mirrors:
4 a few touch up paint work on a few chips.
5. SAFC setup
Option 2- Power:
98
highflow/big turbz
nistune
+supporting mods.
Now, I'm siding with the cosmetic with a SAFC piggyback given that my mirrors are absolutely shot and need to be repainted (replaced with CF mirrors in this case). Bonnet has a few marks and well, the boot is a nice touch to it. I'll be going wingless and that's pretty much about it. Cons for Cosmetic is that the car does live outside :(
And, one day when I do finally upgrade to a GTR the mirrors and boot lid can come across with me
Power:
No real pros except for... the thrill of acceleration (My ultimate joy).
Cons would be more things to break, more fuel usage etc.
Anyone with their 2cents of experience?
Edited by RosieR34
Thanks for the input everyone, I really didn't mean to cause such a fuss :wacko:
During the past 6 months of trying to rectify this I was amazed by one thing, both Chris at Inline and Capital S + S told me that the brand of tyre can make a huge difference. When I had this proved to me and I changed all tyres from Pirelli to Yokohama it was an amazing difference, like a different car. So with the trye change I came from a huge problem to a minimal one, I think from here it's in the 'fine tuning' as Mik suggested.
So like the lady she is I'll continue to fiddle with her, treat her kindly, service her regularly and give her a good hard drive every now and again, and life will be good.
Thanks to one and all ... :thumbsup:
  • Like 2
Option 1-Cosmetic:
1.CF Boot lid:
3.CF mirrors:
5. SAFC setup
Option 2- Power:
98
highflow/big turbz
nistune
+supporting mods.
Power:
Don't bother with the SAFC imo.
Only something you will need to replace down the track
If you don't want to change the turbo etc
than Nistune is a good option to make the car drive much nicer, have more power, and better economy without needing to change turbos/injectors etc
As for the carbon bits.....it just screams "defect me"
  • Like 1
Option 1-Cosmetic:
1.CF Boot lid:
3.CF mirrors:
5. SAFC setup
Option 2- Power:
98
highflow/big turbz
nistune
+supporting mods.
Power:
if it lives outside don't get anything CF. CF gets damaged by the sun really badly. you will have to coat it alllll the time. Also what zeb said.
Speaking of Nistune, who does it locally? or should I say, who should we go to locally to get this done?
Only choice is Ed at Autotech in hume.
He did mine and got 245rwkw with Nistune
will need a few extra bits (like injectors + Fuel Pump)
Edited by Sinista32
hmmm worse than red? :'( man that sucks. Was getting a tad excited.
Might just get the mirrors and some power
Jeremy, excitement is in the eye of the beholder .... fast mirrors are always cool and a little 'classy' and power will give you that warm an fuzzy feeling inside, power is the gift that keeps on giving. :closedeyes:
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
