Jer this is all you need to notice an improvement like what zebra said
Nistune = $400
Tune = $750
Total = $1150
Optional addons
AFM = $200
Injectors = $600
Fuel pump = $200
Coilpacks = $450
Turbo = $900
Plus any parts that aren’t working that are discovered at the tuning phase... :unsure:
I had some nice surprises...
- Coilpacks = $450
- VCT Solenoid = $200
Even after buying an aftermarket pump (bosch 040) It wasn't working properly. Threw in a Walbro = $110
Great surprises!
It was totally worth it though. Fixed some small bugs I had plus the power. Best 3-4k spent on the car
Edited by dontyellpl0x
Jez no need for a turbo.
You could go from 150-160rwkw now to 190ish just with nistune and a bit more boost.
Believe me it makes a difference.
Not to mention you can get a big gain in the midrange which makes them a lot of fun
The benefit of a Nistune would be the option to retune for more power with more supporting mods down the track.
ie. injectors and Hiflow etc. (SAFC won't really do this)
I thought the gains would potentially be greater than that for just a Nistune and tune though.
For 2.5k-3k. I would get a Haltech, RB20 Wastegate actuator, a walbro pump and a tune. Should be about $2.7k. Would make about 220rwkw which is heaps.
- Injectors should handle up to 235rwkw
- R34 Stock Turbo should be a OP6 so it's big anyways
- Haltech is better than Nistune.
I think the above prices are not installed, so you would need to include labour. Labour is expensive at between $90-$140 per hour. Haltech, wastegate and pump should be easy to install yourself.
  • Like 1
Yeah :( I am kicking myself that any direction over 200kw is at least 3k. Hmmmm
edit: Cheers guys for the info. I think a hard decision will need to be made in the coming of weeks.
Edited by RosieR34
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
    • Very hard to make out what you mean, is it the squarish hole with redline shockproof (probably) under it? Is that pic from on top of the engine with the firewall to the left of pic and engine to the right? Either way, spray the area liberally with degreaser and try again, maybe circle the part you are worried about
