Yeah Jeremy, dont go all out yet.
Because big power costs a lot to get but..... thats only half of it.
You will need other things upgraded to make it useable and safe.
What some people do is work out a final goal, and buy things that will work for that goal. You dont have to have it all at once.
Brakes, maybe wheels and tyres, clutch, possibly driveshaft, diff centre, better suspension, instruments, etc.
Try and write a list of everything and add up the cost, its not cheap. Its almost not worth it when you look at it that way.
For example if you get a computer, get one that will accomplish what you want before moving on to a better car.
Would you bother spending that much on a gtt or just save for a gtr one day?
This can take a while to figure out, and the more you know the easier it is.
And, yes, google is the only way you will ever find out enough. :yes:
Edited by D.I.Y. Mik
  • Like 1
Awww, nice.
But look closer, it has old 32 syndrome, a hit in the front has pushed the headlights in a bit at the centre. (Not as bad as mine)
GTSTs and such were not pampered and looked after like some GTRs.
Also a reminder that some of us are heading to sdma tomorrow for some quality queanbo hillclimbing - http://www.skylinesaustralia.com/forums/topic/446214-sunday-at-sutton-rd-hillclimbs/
You know the deal! The more the merrier blah blah :P
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
