Yeah Jeremy, dont go all out yet.
Because big power costs a lot to get but..... thats only half of it.
You will need other things upgraded to make it useable and safe.
What some people do is work out a final goal, and buy things that will work for that goal. You dont have to have it all at once.
Brakes, maybe wheels and tyres, clutch, possibly driveshaft, diff centre, better suspension, instruments, etc.
Try and write a list of everything and add up the cost, its not cheap. Its almost not worth it when you look at it that way.
For example if you get a computer, get one that will accomplish what you want before moving on to a better car.
Would you bother spending that much on a gtt or just save for a gtr one day?
This can take a while to figure out, and the more you know the easier it is.
And, yes, google is the only way you will ever find out enough. :yes:
Edited by D.I.Y. Mik
  • Like 1
Awww, nice.
But look closer, it has old 32 syndrome, a hit in the front has pushed the headlights in a bit at the centre. (Not as bad as mine)
GTSTs and such were not pampered and looked after like some GTRs.
Also a reminder that some of us are heading to sdma tomorrow for some quality queanbo hillclimbing - http://www.skylinesaustralia.com/forums/topic/446214-sunday-at-sutton-rd-hillclimbs/
You know the deal! The more the merrier blah blah :P
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
