[EDIT: This is now my "what is wrong with the car at the moment" thread.]
[EDIT: It will also be my "what I'm upgrading/doing with car at the moment"]
[scroll to the bottom to see what's doin with the car!!]
Sweetas.
I might be in for some track days comin up since my car didn't blow up after my fire. It's been re-wired a little now and hopefully won't be bursting into flames in the future.
After replacing a ****load of parts I don't think I have too many left to go and I might actually be back on the road for longer than a week!
When's the next time you guys are cruising/track-daying?
https://www.sau.com.au/forums/topic/55349-wohoo-my-car-didnt-blow-up/
  • Replies 199
I call it as I see it.
I am helping cc in any way that I can to get the car in safe working order. There is some seriously bodgy stuff on the car that is frustrating the hell out of cc.. eg, the engine mounts didn't have nuts on them on EITHER SIDE. I don't even know what was holding the engine in.
There there is all the disconnected vac hoses, and exposed wires (causing engine fires etc).. The bride seat was only bolted in with 3 bolts as the wrong seat rail was used. The list goes on...
I guess it will all get fixed in time, but I just hope some of this doesn't cause a real serious safety issue before he fixes it
I agree with you too_much_boost........safety first. But how did it get a safety certificate to transfer the rego with only 3 bolts holding in the seat? Or without the engine mount bolts?
I heard CC bought the car pretty cheap..........was it cheap enough to SORTA warrant the screw around?
Cars not registered in my name yet RS so it has not gone through engineering.
The few probs too_much has outlined are nothing compared to everything else that's happened and I still have to fix.
So no.. for the price it really wasn't worth it (ie. i should have imported my own).
Not good to hear CC...........but i suppose to a certain degree it comes with buying a modified vehicle.
I hope you get out of it for as little money as possible.
Can i ask what you paid for yours? I have one coming from Japan soon with similar gear.
Cheers mate
I think I'll keep adding to this thread as shit keeps ****ing up - so please check back often to see if you can help me (maybe you tripped an old lady this week or kicked someone down the stairs at the train station and need something for the guilt.)
On Saturday I was rolling down a road (as you do) and noticed the car was burbling and losing power when I applied the accel, sorta sif a intercooler pipe had fallen off.
I pulled over and checked all the piping and it was fine.
I couldn't get the car started again. I noticed when I turned the key to ON I couldn't hear my fuel pump come on, as if usually the case, instead my injectors just go "clickclick" really quickly instead.
Had to get it towed.. again.. *sigh*
Will keep posted as to the outcome.
Thats no good man :P A car with continuing problems is just a nightmare.
Sorry to hear its got so many troubles.. over in japan, sometimes there idea of "fixing" isn't much better than your very worst b-grade mechanic over here - you hear some terrible stories.
Wow. that sounds awful mate. You should have bought my GTI-R instead :uh-huh:
I'm sure once it's sorted it'll all be ok. There is nothing so bad on a car that can't be fixed with enough time and money...
Richard
Sorry to read about your dramas, i had a run of bad luck, i think i have turned it around now, thank god. Hang in there, you bought the car becuase you obviously liked it...so hang in there and things will come good.
My old R31 GTSX had been modded by a few questionable local folk as well...took 6 months to get sorted, but was worth it in the end.
For what its worth if you need any running around done in Melb let me know, there seems to be plenty of Ceffie owners down here, and if its a matter of sussing out parts then i can help pick/post etc etc
Richard
YES I actually thought about that because I remember speaking to you - I *should* have bought your car.
I'm hoping for not too much time and money - I've had a bomb project car before and this ones rapidly making that one look like a dream.
Check the battery voltage. That tick tick could be the starter trying to engage but not having enough voltage...
Could explain the fuel pump not working too
Good point - I should have explained tho the tick tick is definately from the injectors (or near them) - the starter DOES tick over fine. I've had a flat battery before - never known em to cut out while driving though ya reckon it's still worth getting a voltemeter?
Thanks Roy, no running around in Melbourne required but thanks.... 6months .. dono if I have the staying power, my old bomb car used to get me lots of girls which offset the fact it was shit :(
Thanks for the thoughts guys :Paranoid: - make me feel a bit better! :throwup:
The fuel pump is triggered by the ecu through the main under dash plug, incidently one of the wires that gets chopped off the rb20 loom and re connected to the sr loom during the conversion. It may be worth checking. It could also be an issue with the fuel pump speed controller, also triggered by the ecu which may explainthe issue occuring when you try to accelerate. May also be worth putting 12V across the fuel pump terminals and see if it is ok or has seized up.
When you get the injector clicking is the car actually turning over? If so then i'd rule out battery and dud alternator and dud connection between them.
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
