R33 series 2 (96)
3" turbo back
fmic 600*300*76mm
high flow'd fuel pump
stock turbo (as mentioned before it has steel compressor wheel????)
Profec b boost controller
175rwkw @ 8-9 psi and 200rwkw @ 12-10 psi (boost drop) and running very rich!
I would like to here any thoughts anyone may have on this dyno run.
Cheers.
got my car tuned today it made 243hp at the wheels or 181rwkw on 11.2 psi
stock turbo
600x300x76 fmic
3inch dump 3.5inch cat back with stock cat
apexi safc series 1
this is a little on the low side i think concidering every one else with stock turbo is making around 200kw do you think its the stock cat or the safc???
97 r33gts-t 209kw/280hp atw (w/dyno sheet)
stock turbo @13.5 psi
stock ecu with SAFC2
3" split dump pipe + full 3"exhaust (still stock cat 4 now)
hybrid fmic
pod with heatshield
turbosmart dual stage boost controller
BP Ultimate fuel
RB25DET Series 1
GT30R turbo
tial 38mm gate
generic stainless steel manifold
PFC + Z32 AFM
600x300x75mm cooler
3" exhaust
740cc nismo injectors
040 bosch pump
k&n pod
blitz spec r ebc
BP Ultimate
324rwhp
about 11psi.
id like to think 350rwhp on a constant 1bar is possible.
Edited by _8OO5TED_
1996 R33 Series 2
Stock Turbo at 11psi(GFB bleed valve)
Apex PowerFc
Z32 AFM
Walbro Fuel Pump
Full turbo back exhaust
K&N Pod
Hybrid FMIC
BP Ultimate
Made 253.7 HP in non shootout mode with safe tune for daily driving. Made more power with turbo at 13.5psi but decided to ease back.
R33 Gtst S1
Results as per my signature... currently 226.5RWKW (will scan dyno sheets in tonight)
More goodies being installed currently with ECU to be installed next week:
555 Injectors
External fuel pump
FPR
ECU (Adaptronic)
Custom Plenum
Metal Headgasket
Cam Gear
Cam Shafts
New hoses throughout engine just incase lol...
GT3540 for when Stage 3 highflow is max'd out
And then..... wait for stock internals to crap themselves before installing a RB30 bottem end :) (Dad won't help me build the bottom end whilst there is a perfectly good one still working in the car :dry: )
Now sitting at 262.3 rwkw on 16psi.. We made 279rwkw on 18 psi but it the highflow was being maxed... dropped it back to 16psi to be a bit nicer the the turbo :banana:
Added the Adaptronic, injectors, fpr, plenum (although awaiting another :) ), cam gear + fuel pump!
Tuned to run really rich due to the plenum leaning out no3 with the airflow. New greddy plenum and Garrett to be installed in two weeks.. will update then when the afrs are a little more friendly to my fuel economy!
1995 R33 Skyline - Series 1.5
Hybrid front mount
Power FC
Walbro fuel pump
Gt3071 interal gate with ground out R33 rear housing
Splitfire coilpacks
3" turbo back exhaust
Greddy profec spec 2 boost controller
Custom intake with pod filter
Stock afm
Stock injectors
Stock plenum
Stock exhaust manifold (except for a bit of porting done by myself)
Pretty safe tune by Mercury Motorsport
Made 234kw atw at 15psi on BP Ultimate
Full boost was seen at 3200rpm with no boost drop off at 7000rpm :wub:
Edited by SmittyR33
PFC shat itself so after getting that fixed and retune the updated dyno sheet is posted.
Performance specific mods ate
Nismo fuel pump
Full exhaust
Custom Garrett turbo
z32 AFM
Blitz FMIC
AVC-R
Power FC
Hard intake pipe
Radiator upgrade
Stock internals
Stock injectors
Stock cams
Next on list:
Injectors
Splitfires
FPR
and then a rebuild.
I had my car dyno today.
I have a 96 GTS-T SII.
Mods so far
A POD
Turbosmart BC Duel
Split dump pipe
Exhaust with a 2" cats and 3" tips.
FMIC
My computer is a Apexi Power FC with HC
Tuned by CRD
12PSI producing 193RWKW
Next group of mods will be
Upgraded Turbo..maybe a hi-flow turbo
Fuel pump
Fuel Reg
Air flow meter
RB25DET
Tomei 256 8.5mm cams
HKS 3037S ex 0.74 56T
Turbosmart 48mm pro gate.
FMIC
3 inch exhaust Catco cat.
550cc injectors.
standard water/oil pump.
Autronic SM2 with 500R CDI
Autronic boost controller
Low boost 16psi 370rwhp
high boost 19psi 400rwhp
Check out the torque curve.....I mean flat line :P
R33 series 1 (95)
Rebuilt engine (forged internals)
Gt3540 .84a/r
Tomei poncams 256
Hks EVC
hks intercooler
twin DIS-4 ignition system
Link g2 ecu
~300wkw @ 14 psi and 325rwkw @ 17 psi
Healthy amoount at this stage but I expect more should come once we finetune the maps later !! :D
1995 R33 GTS-T
std internals
n1 water pump
HKS stage 1 inlet cam
HKS stage 2 exh cam
HKS adj cam gears
HKS timing belt
HKS air filter kit
nismo FPR
Plazmaman plenum
sard 550cc injectors
walbro fuel pump
custom GT3076 ext gate turbo with 0.63ar exh hsg (i would recommend 0.86 for RB25)
TiAL 38mm W/G
s/steel hi mt exh manifold (brand unknown)
GTR front mount custom piping
apexi AVCR (would use HKS controller if i was to choose again)
apexi PFC
It made 259.8rwkw at 7000rpm but has very stong midrange but lower tourque and power tapered off in the top. I will try and get a 0.86 hsg and re-dyno and see what the difference is. But as the package stands it is fun to drive and the boost is only set at 1 bar, so with bigger hsg and 1.1 maybe 1.2 bar it should make 270 kw with more tourque.
This in what i have in my 1991 gtst
Current Mods are:
S2 RB25det engine
RB20det gearbox with a rb30 H/D clutch
3" custom dump/front pipe with a 3" Tanabe catback exhaust
K&N Pod Filter
Walbro 500hp fuel pump
managed to get 211.3rwkws @ 6284 rpm with 1425mn torque (331mn at the flywheel). Only ran 9.33psi of boost
Dyno sheet
Edited by Nishant
    • I think the concept is highlighting the various scenarios where thicker oil helps, and thicker oil potentially doesn't help and only generates heat and costs power, in turn for safety which isn't actually any safer (unless you're going real hot). If anything this does highlight why throwing Castrol 10w-60 for your track days is always a solid, safe bet.
    • Jason should have shown a real viscosity vs temp chart. All the grades have very little viscosity difference at full operating temperature.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
    • I don't think there's any way someone is push starting this car.. I honestly can barely move it, and moving it and steering it is just flat out not possible. I'm sure it is, but needs a bigger man than me. I have a refurbished starter now. The starter man was quite clear and consise showing me how nothing inside a starter really should contribute to slow cranking, and turned out that for the most part... my starter was entirely fine. Still, some of the wear items were replaced and luckily it didn't show any signs of getting too hot, being unfit for use, etc. Which is 'good'. I also noticed the starter definitely sounded different, which is a bit odd considering nothing should have really changed there.... Removed and refit, and we'll pretend one of the manifold bolts didn't fully tighten up and is only "pretty" tight. GM only wants 18ft/lb anyway. I also found a way to properly get my analog wideband reading very slightly leaner than the serial wideband. There's Greg related reasons for this. The serial output is the absolute source of truth, but it is a total asshole to actually stay connected and needs a laptop. The analog input does not, and works with standalone datalogging. Previously the analog input read slightly richer, but if I am aiming at 12.7 I do not want one of the widebands to be saying 12.7 when the source of truth is 13.0. Now the source of truth will be 12.65 and the Analog Wideband will read 12.7. So when I tune to 12.7 it'll be ever so slightly safer. While messing with all of this and idling extensively I can confirm my car seems to restart better while hot now. I did add an old Skyline battery cable between the head and the body though, though now I really realise I should have chosen the frame. Maybe that's a future job. The internet would have you believe that this is caused by bad grounds. In finding out where my grounds actually were I found out the engine bay battery post actually goes to the engine, as well as a seperate one (from the post) to the body of the car. So now there's a third one making the Grounding Triangle which is now a thing. I also from extensive idling have this graph. Temperature (°C) Voltage (V) 85 1.59 80 1.74 75 1.94 70 2.1 65 2.33 60 2.56 55 2.78 50 2.98 45 3.23 40 3.51 35 3.75 30 4.00   Plotted it looks like this. Which is actually... pretty linear? I have not actually put the formula into HPTuners. I will have to re-engage brain and/or re-engage the people who wanted more data to magically do it for me. Tune should be good for the 30th!
