R33 series 2 (96)
3" turbo back
fmic 600*300*76mm
high flow'd fuel pump
stock turbo (as mentioned before it has steel compressor wheel????)
Profec b boost controller
175rwkw @ 8-9 psi and 200rwkw @ 12-10 psi (boost drop) and running very rich!
I would like to here any thoughts anyone may have on this dyno run.
Cheers.
got my car tuned today it made 243hp at the wheels or 181rwkw on 11.2 psi
stock turbo
600x300x76 fmic
3inch dump 3.5inch cat back with stock cat
apexi safc series 1
this is a little on the low side i think concidering every one else with stock turbo is making around 200kw do you think its the stock cat or the safc???
97 r33gts-t 209kw/280hp atw (w/dyno sheet)
stock turbo @13.5 psi
stock ecu with SAFC2
3" split dump pipe + full 3"exhaust (still stock cat 4 now)
hybrid fmic
pod with heatshield
turbosmart dual stage boost controller
BP Ultimate fuel
RB25DET Series 1
GT30R turbo
tial 38mm gate
generic stainless steel manifold
PFC + Z32 AFM
600x300x75mm cooler
3" exhaust
740cc nismo injectors
040 bosch pump
k&n pod
blitz spec r ebc
BP Ultimate
324rwhp
about 11psi.
id like to think 350rwhp on a constant 1bar is possible.
Edited by _8OO5TED_
1996 R33 Series 2
Stock Turbo at 11psi(GFB bleed valve)
Apex PowerFc
Z32 AFM
Walbro Fuel Pump
Full turbo back exhaust
K&N Pod
Hybrid FMIC
BP Ultimate
Made 253.7 HP in non shootout mode with safe tune for daily driving. Made more power with turbo at 13.5psi but decided to ease back.
R33 Gtst S1
Results as per my signature... currently 226.5RWKW (will scan dyno sheets in tonight)
More goodies being installed currently with ECU to be installed next week:
555 Injectors
External fuel pump
FPR
ECU (Adaptronic)
Custom Plenum
Metal Headgasket
Cam Gear
Cam Shafts
New hoses throughout engine just incase lol...
GT3540 for when Stage 3 highflow is max'd out
And then..... wait for stock internals to crap themselves before installing a RB30 bottem end :) (Dad won't help me build the bottom end whilst there is a perfectly good one still working in the car :dry: )
Now sitting at 262.3 rwkw on 16psi.. We made 279rwkw on 18 psi but it the highflow was being maxed... dropped it back to 16psi to be a bit nicer the the turbo :banana:
Added the Adaptronic, injectors, fpr, plenum (although awaiting another :) ), cam gear + fuel pump!
Tuned to run really rich due to the plenum leaning out no3 with the airflow. New greddy plenum and Garrett to be installed in two weeks.. will update then when the afrs are a little more friendly to my fuel economy!
1995 R33 Skyline - Series 1.5
Hybrid front mount
Power FC
Walbro fuel pump
Gt3071 interal gate with ground out R33 rear housing
Splitfire coilpacks
3" turbo back exhaust
Greddy profec spec 2 boost controller
Custom intake with pod filter
Stock afm
Stock injectors
Stock plenum
Stock exhaust manifold (except for a bit of porting done by myself)
Pretty safe tune by Mercury Motorsport
Made 234kw atw at 15psi on BP Ultimate
Full boost was seen at 3200rpm with no boost drop off at 7000rpm :wub:
Edited by SmittyR33
PFC shat itself so after getting that fixed and retune the updated dyno sheet is posted.
Performance specific mods ate
Nismo fuel pump
Full exhaust
Custom Garrett turbo
z32 AFM
Blitz FMIC
AVC-R
Power FC
Hard intake pipe
Radiator upgrade
Stock internals
Stock injectors
Stock cams
Next on list:
Injectors
Splitfires
FPR
and then a rebuild.
I had my car dyno today.
I have a 96 GTS-T SII.
Mods so far
A POD
Turbosmart BC Duel
Split dump pipe
Exhaust with a 2" cats and 3" tips.
FMIC
My computer is a Apexi Power FC with HC
Tuned by CRD
12PSI producing 193RWKW
Next group of mods will be
Upgraded Turbo..maybe a hi-flow turbo
Fuel pump
Fuel Reg
Air flow meter
RB25DET
Tomei 256 8.5mm cams
HKS 3037S ex 0.74 56T
Turbosmart 48mm pro gate.
FMIC
3 inch exhaust Catco cat.
550cc injectors.
standard water/oil pump.
Autronic SM2 with 500R CDI
Autronic boost controller
Low boost 16psi 370rwhp
high boost 19psi 400rwhp
Check out the torque curve.....I mean flat line :P
R33 series 1 (95)
Rebuilt engine (forged internals)
Gt3540 .84a/r
Tomei poncams 256
Hks EVC
hks intercooler
twin DIS-4 ignition system
Link g2 ecu
~300wkw @ 14 psi and 325rwkw @ 17 psi
Healthy amoount at this stage but I expect more should come once we finetune the maps later !! :D
1995 R33 GTS-T
std internals
n1 water pump
HKS stage 1 inlet cam
HKS stage 2 exh cam
HKS adj cam gears
HKS timing belt
HKS air filter kit
nismo FPR
Plazmaman plenum
sard 550cc injectors
walbro fuel pump
custom GT3076 ext gate turbo with 0.63ar exh hsg (i would recommend 0.86 for RB25)
TiAL 38mm W/G
s/steel hi mt exh manifold (brand unknown)
GTR front mount custom piping
apexi AVCR (would use HKS controller if i was to choose again)
apexi PFC
It made 259.8rwkw at 7000rpm but has very stong midrange but lower tourque and power tapered off in the top. I will try and get a 0.86 hsg and re-dyno and see what the difference is. But as the package stands it is fun to drive and the boost is only set at 1 bar, so with bigger hsg and 1.1 maybe 1.2 bar it should make 270 kw with more tourque.
This in what i have in my 1991 gtst
Current Mods are:
S2 RB25det engine
RB20det gearbox with a rb30 H/D clutch
3" custom dump/front pipe with a 3" Tanabe catback exhaust
K&N Pod Filter
Walbro 500hp fuel pump
managed to get 211.3rwkws @ 6284 rpm with 1425mn torque (331mn at the flywheel). Only ran 9.33psi of boost
Dyno sheet
Edited by Nishant
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
