Engine: RB25
STANDARD ENGIN
STANDARD CAMS
STANDARD HEAD
Modifications:
HKS TO4r Turbo KIT
HKS super drager cat back exhaust (3.5 inch)
HKS S type front mount intercooler (custom piping)
Apexi AVCR boost controler
Apexi Power FC
Sard 850cc injectors
Z32 air flow meter
600hp walbro intank fuel pump
Power:1 bar = 279.6 kw @ tires
406.8 nm touque
queensland raceway time.... 58's
Edited by flyline
93 R33 GTS-T
GTR Intercooler
Tomei fuel pump
Apexi pod filter
Greddy Profec B Spec II
Standard turbo
Rebuilt engine
Standard head
3" dump
Big body highflow cat
Straight 3" to Trust cannon
Apexi pfc
z32 afm
Creatd motorsports 720cc injectors
14 psi bleeds down to 12psi (crap actuator)
206.8KW
Tuned at Creatd Motorsports
R33 gtst 1995
Nismo thermostate
Nismo high flow fuel pump
Nismo 550cc injectors
Nismo flywheel
Excedy custom clutch
Eagle conrods
ARP head studs
Arias pistons & rings
Acl engine bearings
Sard sports magnetic oil filters
Sard annodised aluminium cooling oil block
Sard fuel regulator
Nissan N1 oil pump
Nissan water pump
Apex power FC
Greddy remote switching system
Greddy boost controller
Greddy oil catch can
Greddy blow off valve
Greddy intake plenum
Fujitsubo exhaust 3''
Catco stainless high flow cat converter
3" dump pipe
Splitfire coil packs
Front mount intercooler
Custom turbo intake pipe
Custom air box & cold air duct
HKS valve springs
HKS cam shafts 256-intake
HKS cam shafts 264-exhaust
HKS turbo kit GTRS
Bosch Z32 air flow meter
Billion super solid coolant line
40mm radiator
259.4rwkw @ 16.5 psi run in tune
Fuel used - BP Ultimate
second dyno we got lots more torque
Edited by WARLORD
96 SII R33
just had a tune got 222.7rwkw @ 1.0 bar with following mods;
- full exhaust (high flow cat)
- avcr
- pfc
- fmic
- fuel pump and reg
- pod
- iridium plugs
- adjustable exhaust cam gear
- standard turbo
Edited by ICER33
not a turbo upgrade put happy with my result...
stock R33 S2 with only the following
just jap fmic $349
custom exhaust(split dump, 3"system, hiflo cat) $1250
Greddy profec B II $390
Total spent from stock $1989
205.4rwkw at 12psi
hits 11psi by 2300rpm, hits 12psi by 4500rpm for a fraction and drops to 10psi by red line.
r33 sII
Stocker motor
Garret gt30R on top mount staino manifold
Tial gate
740cc injectors
Greedy plenum with infinity throttle body
600x300x100 coller with 3 inch pipework
removal of air flow meter
Microtech LT12
turbo Smart Eboost 2
Bosch 044 pump
Straight through exhaust, no cat or mufflers and screemer pipe
Bilstein coilovers
Malpassi fuel reg
Exceddy clutch on the 3rd one!
392rwhp @ 18PSI dynoed by ovaboost
car has done about 30000kms with this set up and still going strong.
hks 3037 (.68 rear housing)
trust high mount manifold
hks 50mm external gate
550cc injectors
bosch 040
q45 afm
apexi power fc
greddy profec b spec II
hybrid FMIC
3 inch straight through exhaust from turbo back
Got a retune after replacing my cat & crank angle sensor
Highflow by Precision
650cc inj
Sard Pump
Link Ecu
Sard Pressure Reg
3'' Ex with 5'' Stainless Cat
Splifire Coilpacks
232.2 rwkw on 18psi Tuned By CRD
R33 4door automatic 1996 s2
3" straight thru
Hybrid intercooler
pod
stock ecu,motor,fuel pump,coilpacks,injectors,etc :)
BP Ultimate 98
174rwkw at 5psi tuned by (west torrens dyno centre)
Edited by R334door(s2)
Update
just had a retune 9 Aug 07
no mods from below except 98 RON BP ultimate
more timing added with the boost sneaking to 16PSI then dropping back to 13.5 PSI
235 rwKW :nyaanyaa:
cheers
Mike
1997 R33 GTST series 2
HKS 2530 turbo
HKS boost controller
Apexi power FC
Greddy FMIC
turbo back 3" exhaust with metalcat
pod
95 octane pump fuel
1 bar boost
214 rwKw
apexi power fc
E-Boost controller
spitfire coils
bosch fuel pump
sard injectors 550cc
apexi power intake
standard airflow meter (gey!!!)
kkr 480 turbo kit - Dump/ screamer--
Front mount-
229.9rwkw - 18.psi
Gettings cams and z32 - should be a bit higher then hehe!!!
1994 Forged Nissan skyline R33 GTST
Arias Forged Pistons
GTR Rods Prepped
Sard 500hp fuel pump
Sard fuel pressure reg
K & N Pod filter
Garrett GT...
FMIC
3' Exhaust turbo back
50mm Wastegate with screamer pipe
High mount mainfold
ACL Race bearings
WOLF V4
GFB Bleed valve
441RWHP @ 15psi
All engine work done at Imports101 Tuning by Top racing
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
