R34 RB25DE+T
turbonetics stage 2 T3 to4 turbo ext gate
gtr fuel pump
nismo fuel reg
stock injectors & afm
emanage ultimate
jjr fmic
apexi super intake pod
turboback (2.5" dump/front & cat tho) catback is 3"
184 rwkw @ 9psi
Update:
3" dump/front pipes (still with 2.5" cat tho)
Profec B Spec 2
14psi
562.4nM
201.2rwkw @ 174KPH
just had a full retune.... (not a cleanup, full delete and start fresh)
car has:
hks 2835 pro s
greddy rb26 ex cam gear
3" exhaust
hybrid gt fmic
nismo 555cc injectors
nismo fuel pump
z32 afm
splitfires
bcpr7es @ 0.8
pod in box with cai
power fc
fc datalogit
blitz dsbc spec s
car made 280rwkw on BP ultimate 98 and 320 on united e85
very happy with the results as it's a very safe tune.... pulled 2 deg timing out of the top end and only lost 5kw, fixed all the cruise and idle issues, cleaned up a boost spike and got the car running absolutely perfectly.
my thanx again go out to trent & cat @ status tuning, who always go well out of their way to make sure my car is perfect! :)
all graphs are in sae correction mode so the results are the same as dyno dynamics in shoot 6
arias pitons
1.8mm cometic head gasket
spool H beams
arp head, main and rod studs
greddy inlet plenum
80mm throttle body
sard 800cc side feed injectors
040 pump
GT35R with 1.06 exh housing
Vipec ecu
tial 50mm external 'gate
nismo twin plate clutch and billet flywheel
splitfire coils
fully blueprinted
std crank
std head
std fuel pressure reg
+ probably other stuff i cant think of atm
BP ultimate
440 rwhp at 22psi (running out of fuel from the pump)
wasnt done in shootout mode either, was just while tuning, didnt get time for a proper run...
Edited by cuzz_33
1995 series 1.5 R33 Gtst stock internals
(vitals)
- GReddy T67-25g 10cm rear high mount, with external gate/screamer
- modified stock plenum, 90mm throttle body
- splitfires, NGK iridium sparks
- 660cc Sard injectors
- Power Fc+Hc, boost controller
- external 040, internal walbro copy
- Greddy front mount
- stainless high mount manifold
- HKS Pod
- 22-20psi
- BP Ultimate 98
303.6rwkw
(vitals)
- HKS Pod
- 22-20psi
- BP Ultimate 98
303.6rwkw
EDIT external bosch 044
Edited by R31Nismoid
1996 R33 GTST S2
Unopened RB25DET, 188,000kms
Splitfire coil packs
BP Ultimate 98 Fuel
Nismo 555cc injectors
Walbro 255lb/hr fuel pump
PowerFC
profec 2 spec B
FMIC
Mesh air filter with CAI
z32 afm
Garrett GT3071R
3" turbo back exhaust
Adj Exhaust cam gear
243KW@wheels
Previously on stock turbo, injectors afm & fuel pump was making 209kw @ wheels on 11psi
1996 R33 GTST S2
BP Ultimate 98 Fuel
PowerFC
profec 2 spec B
FMIC
z32 afm
Garrett GT3071R
243KW@wheels
Turbo Specs: Comp is .50AR
unsure of turbine AR, but either .64 (more likley) or .71 i have heard thrown around.
1998 R34 GTT
unopened RB25DET Neo, 80,000kms
shell Optimax 98 Fuel
stock injectors
stock fuel pump
nizmo Fuel Pressure Reg
powerFC
greddy boost controller
hks FMIC
hkd pod
z32 afm
Garrett GT3071R
3.5" turbo back exhaust
261KW@wheels @15psi
1996 R33 GTS25T S2 - 92000km
STOCK TURBO
Z32 ECU - NISTUNE
FMIC JJR RETURN FLOW TYPE
K&N PANEL
EBC - Bit under 12psi
3 INCH EXHAUST
SPLIT FRONT/DUMP
187rwkw
Cant say i was over the moon with the result. Oh well.
R34 RB25DET NEO (In R32 GTST)
3" Exhaust
Front Mount
Stock everything except for fuel pump
Adjustable exhaust cam gear
BP Ultimate
Greddy Profec B Spec II (12psi)
Pod filter
Nistune ecu
Stock boost/tune then 12psi and nistuned.
Edited by Hibino
R34 GT-T
RB25DET Neo
Fujitsubo Turbo back exhaust
Apexi Pod Filter
i think stock boost 7-8psi, was a dyno day so dyno operator didnt get time to get boost reading.
Standard ecu, turbo, smic
BP Ultimate
167.1rwkw
STOCK TURBO
Z32 ECU - NISTUNE
K&N PANEL
3 INCH EXHAUST
SPLIT FRONT/DUMP
187rwkw
Upgrade Fuel pump and Z32 Airflow now has 207rwkw on a touch over 12 psi! same dyno. now im happy
1998 r34 gt-t
248rwkw
HKS GT-RS turbo
pod filter
FMIC
Apexi Power FC
forged internals
cat back exhaust cannon style
fuel pressure reg
walbro fuel pump
stock injectors (to be changed to 600cc with new turbo)
stock AFM (to be changed with new turbo)
Just wondering i have sold my GT-RS turbo to make more power was thinking of putting on a garret GT3582 to make the 300rwkw+ mark but would i have a real unresponsive lag monster???? what turbs would people recommend for more power but still responsive?
