ATR43G3 .82 with high pressure actuator:
800cc injectors
Nistune ECU
Z32 AFM
600x300x75mm FMIC
3inch turbo back exhaust
3inch intake pipe with pod.
CP pistons
Stock engine head
Stock cams
Stock cam gears
Stock exhaust manifold
Stock inlet manifold
Stock fuel rail
Stock engine block, Con rod & Crank.
This is a controlled run based on BP 98 Fuel, No boost controller, No wastegate controller.
Video of above run is up for people whom's interested to watch:
R33 GTST turbo PU high flowed .82 with high pressure actuator:
800cc injectors
Nistune ECU
Z32 AFM
600x300x75mm FMIC
CP pistons
Pu high flow .82
Stock engine head
Stock cams
Stock cam gears
Stock fuel rail
Video of 3 dyno runs:
Final result:
rebuilt RB25 with forged pistons etc
GTR Injectors
Z32 AFM
Nistune + RB20 Computer
VCT running via eboost-street between 1500 and 4500rpm
Running 18psi on a GCG highflowed RB20 turbo
Full 3" straight through exhaust with one muffler, split pulse dump pipe.
Makes 236kw @ 6300 - 7200rpm on 18psi, drops down to 15psi by redline due to the tiny exhaust housing.
Makes 210kw on 12psi at similar rpm.
rev limit at 7500rpm
think the dyno is fairly low reading as the car is an absolute animal to drive, turbo has basically standard response and absolute zero lag, can make about 6psi by 2500rpm, full boost by about 3-3.5k
1993 R33 series 1 GTS-T
Hypergear ATR43G2 highflow turbo (0.82ex 0.60A/R)
Nismo 740cc injectors
Bosch 044 mounted in tank
3" Just Jap dump/front pipe, unknown rattly cat (probs gutted/fked compliance or something), 3.5" catback
Splitfire coilpacks
ViPEC v44 ECU
Large FMIC
3" metal intake, pod filter, fibreglass cold air box w/ heat shielding inside
284rwkw @ 15psi on PULP98
R32 with Rb25 with all standard internals
Gt35/40 with 63 rear
6 boost manifold
tiall 44mm external gate
sard 850cc injectors
split fire coils
2 1/2 " exhaust
race cat
haltech e11 v2
blitz dual solenoid boost controller
bosch 044
running 23 psi made 398 rwhp for a year
turned timing down still on 23 psi making 387rwhp
pump fuel
Edited by jordy86
ATR43G3 twiked version in .82 with high pressure actuator set at 17psi:
R33 RB25det fully stock
800cc injectors
Nistune ECU
Z32 AFM
600x300x75mm FMIC
98 Fuel.
R34 GT-T
RB25DET Neo
Hypergear ATR43G3 hi flow, standard nissan compressor housing with 0.82 exhaust housing.
3" Turbo back exhaust
Custom 3" to 2.5" intake with Apexi Pod Filter
Trust Turnflow Intercooler
Z32 AFM
Nismo Fuel Pump
Deatschworks 800cc injectors
Nistune
BP Ultimate 98
279.5rwkw @ 15.8psi, couldnt get the turbo to hold 17psi to redline. Should be some more top end power once we sort that out.
HUGE thanks to Trent from Status Tuning and Tao from Hypergear!! The amount of time they both spent helping sort out issues such as twisting intake pipe, changing spark plug gaps, trying different actuator settings is much appreciated.
R33 Gts-t Series 2
unopened rb25det
Garrett GT3076R .82
RB25DET
Hybrid Front Mount Intercooler
3A Racing Pod Filter
Nismo 740cc Injectors
Z32 Air Flow Meter
Custom 3 inch metal intake pipe
Garrett 3 inch Dump pipe
Modified 3inch JJR front pipe
Fujistubo 3 inch Catback
Greddy Cam gears
Bosch 040 Fuel Pump
Ported Exhaust manifold
Blitz Dual SBC spec r
All controlled by an Apexi Power FC
Making 281.1rwkw with 19psi dropping to 18psi
Next is E85 ;)
  • 3 weeks later...
Nothing new here
But i picked up one of those GCG 3071r copies s/h not realizing at the time how much different it would be
Feels good but wishing i had the genuine garrett now, of course, hindsight is a wonderful bitch
Full boost comes on a bit later than I'd hoped, around 3800rpm. But its done now... :P
@18psi, tapers down to 16psi
Edited by Arthur T3
Duel ceramic Ball bearing OP6 R34 Neo turbo high flow
R33 RB25det fully stock head and forged bottom.
800cc injectors
Nistune ECU
Z32 AFM
600x300x75mm FMIC
98 Fuel.
Video footage
Duel ceramic Ball bearing ATR43G3 Prototype 2
800cc injectors
Nistune ECU
Z32 AFM
600x300x75mm FMIC
4inch intake pipe with pod.
98 Fuel.
Power curve of last two runs. (car's developed a valve bounce issue)
Boost
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
