Nismo thermostate
Nismo high flow fuel pump
sard 850cc injectors
jim berry clutch
Eagle conrods
ARP head studs
Arias pistons & rings
Acl engine bearings
Sard fuel regulator
greddy oil pump
Apex power FC
Greddy boost controller
Greddy type R blow off valve
Greddy intake plenum
Catco stainless high flow cat converter
hks 3-3.75 inch exhaust
hpi split dump pipe
Splitfire coil packs
90 q45
HDI 90mm intercooler
upgrade valve springs
0.5 over size valves
light head port
HKS cam shafts 256-intake
HKS cam shafts 264-exhaust
HKS turbo kit 3037 pro s kit .87
Bosch Z32 air flow meter
40mm radiator
stock exhaust manifold
bit of a boost drop problem but it should be fixed soonish
Edited by WARLORD
post-24119-0-36550000-1330776257_thumb.jpgR32 Gts-t (S1 RB25DET)
FMIC
CP Pistons
ARP Head studs
Sard 555 injectors
Splitfire Coils
High-flow RB25 Turbo with 3076 internals (internal gate)
R32 ECU with Nistune
Bosch 044
Greddy EBC
Factory intake and exhaust manifolds
3.5" Exhaust with high-flow cat
311.1kw @ 18psi on BP98
R33 GTS-T Series 2
GT3076 IW .82
256 Cams
Supporting mods etc...
Caltex E-flex E85
Nismo 740cc injectors
Bosch 040 fuel pump
Still using the standard airbox (ported) and snorkel
349rwkw on 19psi spikes to 21psi
1996 R33 GTS-t SII
Unopened motor
Stock plenum
Stock exhaust manifold
Stock BOV
Hypergear ATR43G3 internal wastegate
ViPec V44
HKS EVC-S boost controller
Nismo 550cc injectors
4in Aluminium Intake
4in K&N air filter
Greddy FMIC
Walbro intank 500hp pump
Splitfire coilpacks
NGK BKR7ES copper spark plugs, gapped 0.8mm
3in Bellmouth dump pipe
3in Decat pipe
3.5in exhaust, no mufflers
375rwhp on 20psi, fullboost by 4200rpm (sorry no dyno graph >_<)
93 model R33 GTST Forgied CP pistons, valve springs and stock every thing else.
550cc injectors
600x300x75mm Front mounted cooler
Xforce 3inch turbo back exhaust
Profect B electric boost controller
ATR43G3 Alternative turbine housing prototype.
4inch intake pipe
Nistune
Z32 AFM in cooler piping
Pump 98 fuel. Car maxed 291rwkws on 19.75psi
(Pink line corrospond to reading above, The blue line was from a different turbo)
Video:
98 R34 GTT - Auto
Blitz return flow
Trust PE II
HKS pod + z32
3" Hard metal intake pipe
Hypergear ATR34 G3 0.82 rear
TurboSmart Eboost 2
TurboSmart FPR800
Walbro intank
Bosch ID 1000cc Inj
MV Automatics Stage 2 kit - valve body + welsh plugs
Nistune
Running KU31 255/30/19 on the rears
A little box slip, which is why the rpm is out - redline set to 7k.
Cooler was a little heat soaked after 30 something runs, and tuner wanted to play with extra load points at the bottom to fix idling.
Could have pushed for 300@20psi, but it was overall too laggy to be my daily and tuner had concerns over bend shaft causing rear wheel to touch the housing.
Decided to ask Stao to resize from an ATR34G3 to an ATR34SS2 to improve response.
Since then there's been some box troubles, so have replaced the solenoids and upgraded 2nd gear to a billet servo.
New tune *hopefully* next week, will post results then.
R34 GTT 2000 85000km
DSR B25 turbo
Walbro intank
Superspark coils
Tomei fuel pressure reg
HKS catback
FMIC
Nistune tuned by Jason@southern motor works
Custom inlet pipe & pod filter
Drift boost tee
Stock internals, stock injectors@ 90% duty cycle, stock afm
Power = 245rwkw @ 162kph & 509nm @ 124kph
Boost getting up to 11psi dropping to about 8psi by 7500rpm need to get a 10 or 11 psi actuator and piss the boost controller off
Edited by Pai Mei
ecr33
Rb25 manual
Blue printed and balanced crank
Eagle H beam rods
Cp forged pistons
custom top mount manifold
t04z garrett turbo, 1.00 rear 0.7 comp
50mm greddy gate-plumbed
Tomei oil pump
crank collar
acl race series bearings
custom baffled gated 7.5L sump and pickup made by yours truly
standard head gasket
HEL oil cooler with thermostatic plate
redline 15w50 fully synthetic oil
full port and polished head
stock valve springs
stock cams
3 inch straight through turbo back with varex
fmic fairly big
plumbed bov
my custom cam baffling
custom s/s catch can
front cam cover to r/h top sump vent
oversize oil returns
1.3mm restrictors (more like 1mm after fitting)
rear head drain
50mm core alloy radiator
nismo 6kg flywheel coppermix singleplate clutch
nismo 555cc injectors
walbro 400l/h pump
haltech e11v2
turbosmart manual boost tee
Im sure iv missed some bits
Tuned by Brent at envydyno
338rwkw at 22psi
varex was a bit restrictive
afr's in the low 11's high 10's
full boost by 5000rpm, peak power at 6000 rpm,
over 8000n of tractive effort
I will eventually do cams and get a smaller exhaust housing and electric boost controller so i can get boost hard by 4000 rpm hopefully.
And the best bit, all legal! everything is engineered.
Iv set it up for track days, hilclimb and occasional drag day. All for fun.
I will post a graph when i get to scanner :-)
Can anyone with and input/info pm me please
Hi,
RB25DET S1
CP forged piston kit
ACL bearings
Cometic Gaskets
HKS 264 cams
HKS GT3037S-56T
HKS ext. Wastegate 50mm
Splitfire coilpacks
Nismo 740 injectors
Greddy Profec B
Z32 AFM
APEXi Power FC
Blitz NÜR Spec exhaust
Unfortunatelly we reached the MAHA LPS 3000 dyno limits, and it tilt down at 5700rpm.... :(
1.6 bar
471 HP @ 5700
579 Nm @ 5200
As It seen on graphs those HP numbers are not the peak numbers, We estaminated 500+HP R33_GT3037_23PSI_.jpg
R33 Series 2 5spd manual
Stock RB25det series 2 engine
-3" turbo back exhaust
-Hypergear Hiflow 21U housing (R33 turbo hiflow)
-Z32 afm
-Pod filter
-Stock injectors
-Frount mount intercooler
-wolbro fuel pump
- Ecu tune by Toshi (by me)
Makes 263rwkw on only 15psi
Here is my sheet for my previous post I cant edit it onto it?
The dip in the top end is from my exhaust, all 3 inch but wastegate is plumbed and I have a varex, which is a but undersize... afrs deliberately left very low at very top...
DVS Drifter
Stock series 2 RB25DET
Ebay SS manifold with Tial MVR 44mm wastegate
Ebay Kando dynamics TD06 20G SL2
Custom piping and 3 inch exhaust
NIStune tuned by me
Walbro gss 342 fuel pump
NO VTC at this stage
No boost controller either
Running E85
Will tune with more boost soon
R33 GTS-T (~150,000km)
Apexi pod filter
Yellow Jacket coil packs
3 inch turbo back
Blitz CS FMIC
Z32 AFM
Bosch 040
Nismo 555cc
Power FC + EBC kit
Hypergear SS1PU custom (Nissan comp housing instead of ATR43)
258.6rwkw @ 15psi on Shell V-Power (98)
Second line is a slightly safer tune with some pulled timing and more fuel, making 252.4rwkw.
98 R34 GTT - Auto
Blitz return flow
Trust PE II
HKS pod + z32
3" Hard metal intake - with some silicon joiner
Hypergear ATRSS2 0.63 rear
TurboSmart Eboost 2
TurboSmart FPR800
Walbro intank
Bosch ID 1000cc Inj
NGK BKR7ES copper spark plugs, gapped ~1.1mm
MV Automatics Stage 2 kit - valve body + welsh plugs +
MV Automatics Billet 2nd gear servo
Nistune
Stao aka Hypergear has a new actuator arm I'm going to buy and test, hopefully it will help hold an extra ~3psi, maybe crack 280rwkw with a retune
r33 sedan
splitfire coilpacks
denso 800cc
bosch044 intank
greddy plenum
china top mount
gt35r 82 rear
tial 44mm gate
apexi avc'r
apexi pfc
tuned with restrictive exhaust for quiet cruising still has more in it but pretty happy with it at the moment.post-75208-0-70521700-1335347550_thumb.jpg
98 R33 GTST
Mods:
X-force dump pipe
Apexi cat-back exhaust
Hi-flow cat
Blitz return flow intercooler
Blitz hi-flow panel filter
Walbro fuel pump
Z32 afm
Z32 Nistune ecu
HKS evc-s 10psi
155rwkw!?
Next mods :coil packs,injectors,clutch and bigger turbo
Edited by dyl33
Enough off-topic chat.
It's the same suspects continually doing it - if you keep going, you'll get a holiday.
Results only. If you want to chat, use the PM function to keep this thread clean and on topic
Thanks.
R33 s2 manual
motor internally stock 73,000kms,
gt30/82 .63
740cc injectors (high flow)
link g4
peak boost around 17psi at 5,000rpm drops to 16psi at 6,700rpm
injectors playing up so did not raise boost not a lot of timing.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
