R33 Series 1.5
Hypergear SS1PU
3" custom turbo back
Blitz CS return flow cooler
Apexi power intake
Yellow Jacket coils
Bosch 040
Nismo 555s
Power FC + boost kit
271.5rwkw @ 16psi on United E85
Black line = E85 high flow cat
Top red line = E85 standard cat
Bottom red line = 98 (252rwkw)
R34 GTT automatic (Tiptronic) that previously had 150rwkw stock and 199rwkw with basic bolt-ons, a bit of boost and Nistune.
The setup:
  • Hypergear ATR43-SS2 internally gated on stock manifold
  • Stock airbox and snorkel
  • K&N panel filter
  • Z32 AFM
  • Scotty's 3" intake pipe
  • Trust turn flow intercooler
  • Turbotech V2 manual boost controller
  • Yellow Jacket coil packs
  • NGK BKR7EIX spark plugs regapped
  • Deatchwerks 800cc injectors
  • Walbro 255 LPH fuel pump
  • JJR 3" bellmouth front/dump (modified)
  • X-Force high flow cat
  • 3" HKS Super Drager cat back (modified)
  • Davies Craig Hydra Cool 678 auto trans cooler
  • Nistune
Result: 257rwkw @ ~17psi, BP 98 Octane
Installed and tuned by Chasers
This is a fairly conservative tune. For some more power, the car needs a better boost controller, possibly a pod intake, and a shift kit.
Edited by V28VX37
ATR43SS5BB Alpha protype1 turbocharger
93 model R33 GTST Forgied CP pistons, valve springs
Tomei 264/8.9 cams, Stock cam gears. NO VCT support.
1200cc injectors
600x300x75mm Front mounted cool
Brae high mount exhaust manifold
HPVA 50mm external gate plumbed back.
Xforce 3inch Cat back exhaust
100 Cell Cat
Profect B electric boost controller
4inch intake pipe
Adaptronic Plugin
Power 490rwkws @ 27psi , E85 Fuel
1996 R33 skyline (SxxRicho)
stock engine,
factory manifold internally gated on E85
FMIC
650cc injectors
PFC
HyperGear High flowed Factory R33 turbocharger with heavy duty actuator.
Peek power of 320rwkws @ 22psi.
R33 series 2, RB25det
internally stock engine
gtx3076r .82 rear housing
6 boost high mount
50mm turbosmart external gate
1000cc xspurts
plazmaman plenum & fuel rail
Vi-pec plugin ecu
600x300x76 cooler
4" intake
434rwhp @ 18psi
6 boost high mount
1000cc xspurts
Vi-pec plugin ecu
600x300x76 cooler
4" intake
434rwhp @ 18psi
Forgot to mention fuel
Rb25det series 2
Npc button clutch
Havoc fabrication steam pipe manifold
Turbo smart 45mm gate
Kinugawa billet t67 10cm
Havoc fabrication return flow front mount cooler
Spitfires
1200cc drop in injectors
Stock inlet manifold
Nismo fuel reg
Walbro 450lph e85 pump
3inch dump that splits into a twin 2.5 bsck out to a 3inch system with 4 hotdogs and blast pipes
Nistune ecu
Tuned by the one and only trent from chequered tuning
Motor is unopened no cams
Made 377rwkw on 23psi extremely safe tune
rb25
mahle pistons
spool rods
poncams
tomei valve springs
ported head
nitto oil pump
6boost manifold
gt3076r .82
turbosmart 60mm gate
greddy plenum w/q45 TB
link g4 plugin
walbro lift pump, 1L surge tank, 044
sard 850's
r34 cas
spitfire coil packs
3 inch exhaust
fmic
301kw@15psi
pump 98
fuel pump was struggling over 6500rpm
Had the Torana retuned on the 25/10 by EFI at Southport on the Gold Coast.
Eng RB 25 NEO std bottom end
Head ported stage 1 pom tom cams lighterned flywheel and 6 puck sprung button clutch.
Manifolds Std Manifolds
Turbo op6 rear housing Hi flowed steel wheel fitted
Injectors Bosh 550cc
Coil packs Spit fires
Exhaust 3" turbo back 100 cell cat straight thorough muf
Nistune chip
Fuel BP98 with C5 fuel additive mixed at 1 can of c5 to 30t of bp98.
Boost spike to 18 psi to get out of the hole drops back to 14 psi for top end (actuator not holding needs upgrade)
Made 285KW@W or 381HP@W depending witch way you want to look at it.
So to have the same power to weight ratio you have to make around 480+ hp@w in a skyline. 2.88hp to every kg the car weight.
Is lots of fun to drive and can make 100ks in just over 3 seconds. 60-170 and back to 0 in 250m.
Edited by lcxu105
  • Like 2
S2 R33 GTS-t
Pod Filter
JJR Return flow intercooler
Stock Turbo
JJR bellmouth front/dump pipe
Venom 100cpsi 5" cat
HKS Super Dragger cat back minus mid muffler
Apexi Power FC
9Psi(stock boost controller-high boost mod)
Bosch 040
BP 98
201.3rwkw tuned by Southside Performance & Dynos
Edited by MatthewT85
97 33gtst hypergear atr43g3 internal gate turbo, nismo 740cc injectors, haltech platinum pro plugin with air temp sensor wired in, yellow jacket coilpacks, tomei fuel pressure reg, 3" open bellmouth single piece dump pipe to decat pipe to 3.5" mid section and 4" at diff to rear muffler. Standard exhaust manifold and standard inlet plenum etc. Heavy duty clutch. 255.7rwkw on 20psi tuned by confidyne motorsport on their mainline dyno
Edited by JAP033
S1 R33, Tuned by Shaun @ Boostworx
Rebuilt RB25 - CP Pistons, ARP Hardware, GReddy Head Gasket
Apexi Pod/Z32 AFM
Greddy TD06l2-20g 10cm Turbo/GReddy SUS Highmount Manifold/Tial MVR44 Wastegate/Turbotech Bleeder
HKS FMIC, Plazmaman Piping kit
Nismo 550cc injectors/Nismo Adj. FPR/Nismo Fuel Pump
APEXi Power FC ECU
3 inch exhaust
270 rwkw @ 19 psi, tapers off to 16 higher in the range, We think the cat (Unknown) might be causing a restriction, so will replace with decat pipe, and remove turbotech and switch to Power FC boost control to maintain boost levels a bit more, but seems turbo is pretty much at it's limits on pump fuel.
May entertain E85 later on, But very happy with the outcome. Midrange is ridiculous, and destroys 235's with ease.
Edited by R31 drift pig
#1
HI All!! just though i would share with everyone my Car and what she made and mods! post what you have , i would like to see what others are running!
im from WA Bunbury
Got it dyno tuned yesterday (Monday)
Mods are
Garret High Flow GT3076R from Adelaide Turbo Service with Factory Rear and front housing
Nismo 740CC Inj
Exeedy Heavy Duty Clutch
Walbro Fuel Pump
Custom Stainless Intake with Cold air induction
Autobahn88 front mount intercooler
K&N Pod Filter
Spitfire coil packs
Iridium spark plugs gapped to .08
Full turbo back split dump HKS 3 inch Exhaust with hot dog and streight through rear (Milo Tin)
HDI Electronic Boost Controller with high and low settting
Haltech Platium Pro ECU
It was a very hot day yesterday! outside temp was around 32 Degrees, the dyno room was 38.5 so it was hot!!! so that would effect the tune a litte bit..
on 19psi i made 359.2 RWHP , took it for a drive and it was nice but didnt like it very much to much wheel spin, so wound it back to 17 PSI which was the sweet spot between good traction and no traction for Final Run and it pulled 337.3RWHP on 17PSI i was happy with that, i can wind it up have a little play if i want as it was tuned to 19PSI
on 10PSI LOW Setting i made 278RWHP
Thanks!!
R33 S2
Stock motor
Kinugawa turbo
Blitz SE return flow intercooler
3" turbo back
Hi flow cat
Stock airbox with hi flow panel
Walbro 255L
480cc injectors
PowerFC
ARK EBC
244.9rwkw @ 17psi on 98 at RTR
Injectors got maxed out and started to misfire due to coilpacks so the tune was pulled back a little.
1999 R34 GTT Skyline
Std RB25DET NEO
Garrett GTX3582R .82 rear w/ anti-surge
6Boost manifold
Turbosmart 50mm wastegate
Bosch 1000s
Plazmaman plenum
Turbo back exhaust
Walbro 460 E85 in tank pump
Splitfire coilpacks
HDI EBC
FMIC
Haltech Platinum Pro ER34 plug-in
425rwhp on 20 psi, pump fuel, hot day.
Restricted at the moment from stock 60mm S1 RB25DET TB and 60mm thick FMIC, was causing too high IAT readings.
Cant wait to get it on E85!
Edited by TheGeniusMoose
1996 R33 skyline S2
stock engine,
FMIC
650cc injectors
PFC
HyperGear ATR43SS2 internal gate Rb25det bolton version
Peek power of 293rwkws @ 17.5psi Pump 100 Fuel.
Similar setup with a R33 21U high flowed turbocharger:
258.6rwkws @ 16psi. Pump 98 fuel
21U Standard high flow profile. Supporting mods and Tomei Pon cams. 271rwkws on 18psi, stock actuator, pump 98 fuel.
1998 r34 gtt 4 door sedan fact manul.
Rb25det neo
Pon b cams
Pfc
Walbro 416 LPH pump
E85
Gtx 3076r . 82 machined out int gate
Uprated actuator
Split fire coils
4" dump into twin front pipes(120mm) in hks super silent exhaust with hi flow cat
Standard clutch
Made 325rwkw 20psi wheel spinning due to using 10" wide super sticky dun lops on 40 psi, dropped to 20 psi but were still way to hot.
Next is upgrade clutch and change rears then up boost
post-91083-13852531056793_thumb.jpgpost-91083-13852531151995_thumb.jpgpost-91083-13852531234823_thumb.jpgpost-91083-13852531325582_thumb.jpg
Back again with E85.
1000cc injectors
unopened rb25.
R33 21U hypergear hiflow (new revision) touching 20psi, back down to 17-18ish top end
splitfires
FMIC
walbro GSS341
3 inch turbo back exhaust with quiet-ish muffler
3 inch intake from scotty. Pod filter
Z32 AFM. Z32 ecu nistune.
etc
Wheelspinning on the dyno with soft 235's made 281rwkw but the power curve was up and down when the wheelspin kicked in. We upped the ramp rate to 35km/h/s and had 2 blokes sitting on the boot and it made 306rwkw but Toshi reckons that's a bit high, more like 290-295 realistically . anyway here are both dyno sheets make of it what you want.
E85 is pretty amazing. So much knock protection
C3jBNd0.jpg?1
CFGjwJS.jpg?1
R34GTT NEO
116000KMS
Stock engine
Stock Coils
NGK .8mm sparkplugs
Hypergear R33 highflow turbo
ASNU105cc
Nismo fuel pump
Stock Airbox
3inch full exhaust (stock cat)
Boost 16psi bleeding off to 12psi
250kw BP98
280Kw E85
th_BryceR34DynoGraphBoost_zps62c2cae9.jp
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
