R34 Skyline RB25DET NEO
- Nistune ECU (Type 4 with Feature Pack 1 - Flex fuel enabled)
- 1000CC ID injectors
- HPX N-1 MAF sensor in 3" tube
- Tomei poncams
- GT3071R turbo
- Trust exhaust system, large FMIC
- Bosch 040 fuel pump
- Jim Berry 300ZX clutch setup
98: 289rwkw @ 17psi
E85: 313rwkw @ 17 psi (Measuring about 78% during the run)
Details:
http://forum.nistune.com/viewtopic.php?f=10&t=3060&p=22711
Edited by darkhalf
  • 3 weeks later...
RS4 Stagea RB25DET NEO unopened engine.
- Healtech ECU
- Factory cams and cam gears.
- HyperGear ATR45SAT turbo
- Havoc Fabrication 3 inches turbo back exhaust
- Walbro 470L/H Fuel pump
- 4 inches Havoc metal induction pipe
- Split fire coil packs
- Turbo smart 44mm external gate from factory exhaust manifold.
- E85 fuel
400rwkws @ 24psi (red) V older turbo (green)
  • Like 3
  • 4 weeks later...
1998 R34 GTT RB25DET NEO
Unopened Motor 160,000km
- Full 3inch exhaust with split dump and highflow cat
- AVCR boost controller
- NPC heavy duty organic clutch
- Nistune ECU
- Siemens 550cc injectors
- Apexi Pod
- 3inch metal intake pipe
- Z32 AFM
- Hypergear R33 21U highflow
- HDI FMIC
- Nismo fuel pump
- Yellow jacket coilpacks
250rwkw on 18psi tuned by Deren (godzilla32) at Tuned Performace.
2000 R34 Gtt
Unopened 130xxx
Highflowed R33 21U
E85
Tomei Dump -> decat -> 3" HKS silent
1400 Xspurts
Scottys custom intake pipe
Go Fast bits EBC
Power FC
50mm radiator
R33 thermostat
Blitz SE return flow
standard coils
Tomei FPR (didn't need it)
Walbro 460 lph
310kw making full boost around 3400-3700? 20psi levels off to around 18
S2 r33 rb25det
Unopened motor
Garrett gt3076 .82 rear
Standard exhaust manifold
Standard airbox and filter
Standard plenum
3inch exhaust with standard cat
740cc nismo injectors
Z32 afm
Power fc
Feels quite strong. Would like some feedback.
Edited by Ryanrb25
R34 GTT RB25DET NEO unopened engine.
- Adaptronic ECU
- HyperGear ATR45SAT-SRFC (Special edition made to work with restrictive return flow coolers)
- 4 inches induction pipe
- Internal gated RB25 bolt on.
- P98 fuel
292rwkws @ 19psi "after the cooler"
Hit 190rwkws @ 4000RPM, Drives very nicely, perhaps another 50kws gain after cooler change.
S2 R33 RB25DET
-CP Pistons
-Stock Rods
-ACL Bearings
-Megasquirt 3
-740cc Deatschwork Injectors
-Walbro Fuel Pump.
-Precision 5857 turbo.
-Tial 38mm Wastegate welded to exhaust housing.
-Boost controlled by the ECU.
-Stock intake and exhaust manifold
-3 inch downpipe to twin pipe 2.5 inch kakimoto exhaust.
It made 406 rwhp (302 rwkw) on 95 pump gas at 18 psi going down to 17 psi. Yea i know, it's the best pump gas we have. It's either this or C16 racing fuel. And my car is a streeter, can't run on C16 all the time.
1998 R33 GTST Series 2
RB25DET
Suspected head work done from Japan (Been told it doesn't look like a standard head, ported, etc)
Front mount
PowerFC
Profec-B II boost controller
Z32
1200cc Five-O motorsport side feed injectors
Walbro 460 fuel pump
HKS 2835 Pro S .68 Rear
Plazmaman plenum
Coolingmist Methanol kit
3" turbo back to diff, then 3.5" from diff to muffler.
299.6rwkw @ 21psi, 820nm of torque on United E85.
Tuned by JEM
From WTAC 2104 RWD class winner's car (Ssxricho).
R33 GTST RB25DET unopened engine.
- PFC ECU
- HyperGear 21U STD high flowed turbocharger with high pressure actuator.
- Front mount inter cooler
- 3 inches turbo back exhaust
- 3 inches induction pipe
- E85 fuel
310rwkws @ 19psi. 20psi @ 3400RPM. That is power and response.
20psi @ 3400RPM.
Build thread at:
http://www.sau.com.au/forums/topic/428535-richos-r33-gtst/?view=findpost&p=7504453&hl=%2Bhypergear
RB25 S1
7.8 ish compression
Weisco pistons
Eagle rods
tomei 260 10.25 cams
Endyn Ported RB26 head
Gutted ITBs and converted to single throttle body
FID 1200cc injectors
pump E85
Haltech PP
6766 precision JB 1.00 divided T4
AFI turbo manifold
3.5 in DP / 4 in exhaust
With some boost control tuning up top and more revs it would have made a bit more, but it was completely out of fuel on the dyno, i normally rev it to 8500rpm
car trapped 136mph making about 630-640whp weighs 3250
Edited by mitchum
Stock RB25DET NEO
HKS GT-RS Turbo
Blitz Return Flow Cooler
Kakimoto R&R Full Turbo Back Exhaust
Apexi Pod Filter
High Flow Injectors
Bosch 040 Fuel Pump
Nistune ECU
Greddy Profec 2 Boost Controller
Exedy Heavy Duty Cushioned Button
Z32 AFM
268.3RWKW Tuned by Race Pace ~ 98 Pulp ~ 17psi
Edited by MariahCarey
  • Like 1
Stock Neo
Stock AFM
Stock Injectors
Walbro pump
Blitz turn flow intercooler
Drift pod filter, Autobarn88 intake pipe
Split dump pipe
HKS 2535
RB25DET
Front mount
PowerFC
Z32
Plazmaman plenum
Tuned by JEM
Hey man I made nearly same power with a HKS GT-RS (:
S1 rb25
Ross forged Pistons
Standard rods with ARP bolts
Rebuilt head
Tomei pon cams
Metal head gasket
Nismo 740cc injectors
Hpi turbo manifold
Hks GT-RS turbo
Custom Rb26 itb's (six throttle set up)
Walbro 460lh pump
Tomie fpr
Turbosmart eboost2
Greddy fmic
E85 20psi @ 3500rpm / 396rwhp @ 7000rpm
S1 RB25
Unopened motor
Bosch 040
Nismo fpr
Power enterprise 850cc injectors
Splifire blue jacket coilpacks
Z32 afm
High mount GT3076r 0.82 (yeah China)
Steam pipe manifold
Tial 44mm MV-R
Full 3-inch straight through
Greddy front mount cooler
Greddy forward facing plenum
Power FC
Greddy Profec B spec II ebc
Made 270rwkw @ 7400rpm
Running BPU 98 @ 18psi
Edited by Nevastator
  • 4 weeks later...
Rb25 neo. Stock bottom end. Stage 2 cams greeddy inletmanifold with 1000cc bosch injector twin 044s spitfire coil packs custom made hi mount manifold gtx3582r turbosmart hypergate with 17psi base spring. Suppect v bands leaking not sealing properly. 3 inch straight through exhaust with 100 cel cat. Dumped at diff.
Bp98 fuel made 422.3rwhp
  • Like 1
  • 4 weeks later...
Hi guys
I think I am the first to post up the results of a Mamba brand turbo. The unit is fitted to my series 2 Stages RSFourS RB25DET-Neo. I took the plunge and contacted Eiji directly for my purchase and couldn't be happier. The dyno results speak for themselves, I will be sticking it back on the dyno to get the 300rwkw I was chasing, and it looks very achievable. Tuned by the wizard himself Dec's from Garage 7, he had to stop the tune early due to the clutch losing its ability to hold the power, a standard clutch was never going to cut the mustard. New clutch ordered and it's almost guaranteed I will be making a post in the '300kw unopened club' thread.. So, see below.
RB25DET-NEO Manual Stagea RS4S
KPM Motorsport StreetFighter Bosch 1000cc 3/4 Length injectors
Pump 98 Fuel
walbro 460lph in-tank fuel pump
Mamba GTX3076 turbo with .82 rear housing
HDI FMIC, customised into return flow setup
Hybrid Low Mount Manifold, Customised external gate outlet
Synapse 40mm External Wastegate (screamer outlet)
Full 3" exhaust, decat and 2 mufflers
Power FC for R34 with Squirrel trick
70ebfa4e-5131-498d-9b8b-f53b997cbdd0_zps
e3a85764-c032-4674-9991-961343084a2e_zps
11356308_10153102781404024_735295822_n_z
11418445_10153102781444024_821475343_n_z
Edited by boothy_99
  • Like 2
R34 GTT
Stock turbo
Stock SMIC
Stock injectors
CES 3" turbo back exhaust
RB20 wastegate actuator
Nismo fuel pump
NIStune
98 RON fuel
192kw 11psi
Upgraded turbo to GTX3071R .82 rear internally gated
Blitz return flow FMIC
Xspurt 1000cc injectors
Ceramic coated split dump pipe, custom 3" front pipe, Venom 100cpsi 3" cat
Nismo fuel pump rewired with relay
Splitfire coilpacks
Metal intake pipe
Z32 AFM
Standard airbox
Nistune
98 RON fuel
263.8rwkw @ 16psi (wastegate pressure)
Started getting detonation issues probably due to the return flow FMIC, left the tune at wastegate pressure for regular track use.
Green line is stock turbo
  • Like 2
  • 3 weeks later...
R34 GTT
1000cc Bosch injectors
Hypergear ATR43SS-2 internally gated bolton turbocharger
Adaptronic Plugin ECU
Just Jap's Front mount cooler piping kit
Just Jap's Turbo back 3 inches exhaust
100 cell cat (don't know the brand)
Tuned by Chequered Tuning
Pump 98 fuel
PWR 600x300x81mm cooler:
295rwkws @ 19psi aftercooler (blue is from using Takashi 600x300x100mm cooler)
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
