Sorry to do this kinda thread again, but all the others get caught up in bull$hit stories. Only people that actually HAVE/HAD PowerFC's or Wolf's need comment in here as I don't want to hear "I heard my mate done this and it f*cked up that"
I'm lookin for a new ECU/Turbo package.
I'm trying to decide between a Wolf3D, or a PowerFC for the job. I wanna know disadvantages/advantages of both and experiences anyone has had with them. Healthy debate only please. LOCAL people only too please.
The PowerFC can be had with hand controller for around $980 - $1000
The Wolf3D can be had for around $1400 I'm told.
Benefits of Wolf
*Rotational Idle
*Antilag
*Boost Control
*Uses MAP Sensor
Benefits of PowerFC
*Large range of Tuners
*More Maps?
*Plug'n'Play
Okay, let me know what you think....
https://www.sau.com.au/forums/topic/56679-show-of-hands-powerfc-or-wolf3d/
  • Replies 125
Wolf do a plug and play for the R33 as well.
Doesn't come with rotational idle though.
Tuning would mainly be done by one shop as they are very good at getting results out of these things that other shops can't.
We have an as new one for sale for $1150
Power FC is a very good computer and has a wider tuning base to work from( ie more shops will do them ).
There are pros and cons for both which I'm sure will only end in a bitch fight again so I suggest you talk to people in PM who have them and ask for there opinions re hot start, cold start, ability to drive large injectors, fuel consumption and cost to get it properly tuned.
Cheers
Ken
Con,
Both computer systems are good.
Something to note is that the power FC uses the MAP sensor inputs much more than most people realise. You can watch the tracer move across the fuel/ignition maps when on boost, ie across the rev range on a fixed Map input.
Personally, I use the Power FC, but there again I only have 300 rwhp.
Programming it is a snack. It starts reliably, hot or cold and drives like an unmodified factory offering.
The decision comes down to this:
The power FC runs better when cruising around town, but can be constrained by airflow meters (In terms of overall flow) at full noise. Power FC will run large injectors well.
Wolf 3D has most of its benefits in large HP motors & will use more fuel when cruising.
For my 10 cents worth, if you are not going for silly horsepower, Power FC is the go.
Both units are the only way to go with Street R33s, The only advantage we have is boost control standard and MAP or MAF sensor plus an Australian warranty.We sell and recommend both. PFC is avalible with MAP sensor now. It only comes down to what is the best deal you work out but take boost kits and larger AFMs into count if needed.
Barries dyno is another shop that does well with Wolfs.
We can give you a demo on both.
Had PFC in both my GTSt and the R.. Never had a drama with either of them, starts perfect everytime. Having said that I'd happily give the wolf a try considering some of the results the boys have got with em...
I run 700cc injectors and the PFC handles em fine.
Would you honestly use antilag if you had it????
Well i have the Wolf and seem ok with it.
the only prob i have is that my air con when turned on keeps stalling the car, i have now spoken to workshop and this can fixed!
ALL GOOD!! and am happy chappy!!
go wolf..... have you ever heard how cool rotational idling sounds!! stuff anti lag rotational idling sounds Yummy!
Brett,
Hell no - but Its one of those things, I'd rather have it and not need it rather than need/want it and not have it... :D Rotational Idle I would have but :D
Dan,
I'm assuming you're using an external EBC, and not the in-built wolf boost control ?
Stuff like that - the aircon stalling is EXACTLY the kinda stuff I want to know :) Thanks
If i had my time again I think I'd go the PFC a lot of initial cold start issues and the auxilaries (like air con, full lock on the steering wheel causing the power steering pump to work harder) coming on making the car stall. I think the PFC and hand controller will also tell you how much engine knock you have, dont think the wolf does that and more tuners around for the PFC as well.
I had a PFC in my old S15 and until recently a PFC in my R. I liked them and found the HC a useful "extra gauge". I particularly liked the knock monitor function as this gave me a good indication as to "how far from the edge" the car was tuned. This helps with "road tuning" for conditions that don't show up on dyno runs (such as very hot weather, sustained high speed/high boost runs on the open road etc).
Without a Datalogit, the PFC is a time consuming to tune. Note that there are firmware quirks between the models with the PFC and not all of the older models are supported by the Datalogit. If you want to be able to log data and change maps (even infrequently), then the Datalogit is essential.
When you factor in the cost of the PFC, HC, Datalogit, bigger AFM's, it actually starts to become a fairly expensive package.
I've chosen to go the Wolf route as I've seen some excellent results first hand from SST on GTR's. For me it's a case of following in the footsteps of people that have achieved first hand what I am aiming for.
My advice is speak to and spend time with owners of each unit and weigh up the pros and cons based on where you (realistically) want to go with your 'line.
My opinion for what it's worth.
I have been running the power FC for a few months now and have been nothing but happy with the results. Everything works the same as it did with the factory ECU (air-con, cold start etc) and I get reasonable power with decent fuel economy.
For a dedicated daily driver and only chasing modest power I think the power FC is a good option. As far as costs go though, I don't think it is necessarily cheaper when you factor in an AFM('s) and EBC on top.
Disclaimer: I don't know much about either ECU, I just know I have had no probs with what I've got.
I've just gone with a PFC also. Very very happy with it. Only prob I am having at the moment is that sometimes it wont start first time, and when it does, shitloads of "fuel" smoke leaves the exhaust. Any ideas as to how I can fix this?
But yeah, everything I would have said, has already been said....so I will leave it at that.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
