gr33ddy - Please check your PM's regarding the Oil Cooler I ordered, you have been active since I PM'd you, So I am guessing you missed that you had new PM's.
I need to sort this out ASAP.
Cheers
Chris
  • Replies 141
Hey, I was wondering if the CAI would also fit in an NA R33, looks to me like it would but im not 100% sure, if they do i was also wondering if you had any left or were getting any others in, thanks
  • 1 month later...
Received my R34 Radiator Panel today... can't wait to fit it!
Absolutely awesome delivery time considering distance from SA to NSW; definitely recommended as a seller! :rolleyes:
  • 3 weeks later...
Carbring style Clear top Cold Air Induction Box
for R33 GTS-T, R34 GTT
high quality aluminium made
Bolt on, come with everything u need
$190 posted
Aluminium hood panel
Improve cooling efficiency by forcing the cold air goes to the radiator
finished in silver
R33, S14, S15 -  $105 posted
R34                -  $110 posted
Apexi style cold air induction box
fit S14, S15
$140 posted
interest buyer con contact me via PM :wavey:
P.S.
pls only pm me if u are geniune buyer
negative comment will be given to time waster
Am interested if you have any CAI for a R33 GTST left. Radiator deflector too if have any!:
email: [email protected]
sort out the problem with supplier,
so CAI box and panel are now available again!
got a few CAI box in stock
and still waiting for panel
but won't be long
interest buyer can contact me via PM :D
Edited by Maxx
  • 3 weeks later...
Hi Maxx,
Received the box today (ummm yesterday) all is good
Man that's fast shipping from HK !!
Maxx roxx & his boxx kixx ass. ^_^
Edited by BigDatto
Hi there im interested in one of these CAI Boxes. I dont have an intercooler too improve cooling. With this Box and a Pod has anybody noticed any increase in heat or is it the same as having the stocky box but with cool induction noise. At the moment my car is stocky but all im going to get is a turbo back exhaust and I want the cool sound without going the BOV because of problems associated with them.
it should be better than stock air box (bigger volume, better flow) + with cool induction noise, which design for stock cooler piping.
An improve version for aftermarket cooler piping will be release shortly
Hey Maxx,
CAI Box for the R34: does the entry for the stock snorkel sit at EXACTLY the same place as the stock air box? After my FMIC install, i modified my snorkel to fit around the piping so I only want to go Pod if I can retain that snorkel :blink:
Secondly, these new boxes, do they have 2 holes? One for the snorkel and one for a CAI tube?
I might be interested in a clear top box for R34 :D
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
