yo, im realy intrested in 1 ov your cai boxes and im sure alot ov the 33 crew on tha coast will be too! i was going to make 1 myself but i dont mind spending the money and getting 1 made. i have the stock intercooler but i cant understand where the pod will get the cold air from.
Im realy keen on 1 ov your cia boxes if u fill me in where the air is coming from. will have to be next week as i just spent 600 on a hks sequential. keep me posted.
Gamma :(
  • Replies 141
yeah around 600 with adaptor, ssqv, gettin fitted tuesday. i dont hav the snorkel where can i find 1, ive posted an add in tha wanted forum. Do they come with a snorkel (probs stupid question). if i can get tha snorkel well do buisness 4sure!!!
keep up tha good work.
they dont come with a snorkel but ur bound to find one on the forum sooner or later. maybe even ebay?
I didnt really notice a difference in performance - guess I got one cos most people were sayin that Iwas better off with a cai box over the top of the mushroom! (but Ive also read that a good panel fiter can be better!!) :confused:
Ah well - they look good!!
they don't come with the snorkel, but i got 1 at home.
u can have it for $15 :)
thanks Paul for answer a lot of the question too, hope every customer are as good as u :(
  • 3 weeks later...
Hi maxx,
Any available for r33 gtst? i am in melbourne. Let me know cost including shipping
Also what pod filter is suited for this box? Can you supply that as well or exact model?
can u custom make them to be feed tru the snorke AND a duct hose on the front of the box, [as in from the front bar to the front or bottom of the box..lets say 4inch hole to fit a ductin hose? for r33 s2 by the way
paulR33: i still got 1 left i think, but already order some from supplier which should be ready.
it will fit "most" pod, from what i know, HKS, K&N, blitz, apexi... enough? :cheers:
i don't have any normal top now, as i only sell 2 of them, 99% buyer wants clear top.
Josh: i never try to fit it to a R32, but we can work something out, PM me
fazt_r33: i can :P
  • 1 month later...
Hey i'm interested. What holds the box in place? Do i have to drill holes in my engine bay or what? Also has anyone else got this and noticed any power difference or got any dyno figures?
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
    • This is what the look like normally. Except we only got the 2 doors locally
    • Back pressure is not really a function of the exhaust itself, but the turbine/housing. So the question/point remains valid. I would be fitting an EMAP tapping point and seeing what is going on in the exhaust manifold before committing to throwing boost at it. Flow. No intercooler is actually rated for continuous operation at any power level wrt temperatures, as they are no actually capable of shifting the required amounts of heat on a continuous basis. They get hot during a pul, then dump some of that heat into the external air (and some back into the internal air) during off load moments/periods). You probaby do need a bigger core, given the power level you're already at is somewhat above the "rating" of the cooler. Put pressure tapping points either side of the core (which possibly you already have, if you have a boost source near the compressor outlet and tapping near the throttle for existing purposes) and report on delta P across the core.   I haven't done the mass flow calculation to see where you would be sitting on the compressor map at the ~450is rwkW level we're talking here, but if you look just at the PR you're running at, which is ~2.8-2.9, then you have a really really wide swath of the compressor map to run in, and so long as you were making between about 45-75 lb/min of flow, you should have really good comp efficiency, with the ideal being betweem 55 and 65. I can't see the need to shift drastically on the map to get better results.
    • Welcome 🙂 The ER34 wheels and slight lowering suit the R33 sedan really well. I'm firmly in the 'keep it stock, at least on the outside' camp.
