380hp
and its making 306rwhp on 18psi with a lack of timing
tuner said it will easily make 320+ on only 18psi, just need to fix the miss :)
Will be interesting to see what you can get out of then. If you are able to get 250-260rwkws (340-350rwhp) out of it and still have good bottom end...then yeh the theory with the manifold will be taking a beating. :D
Hi Guys
My HKS cast manifold is of at afe being flow tested at the moment will post results when I get it back though he still recons that will be a couple of weeks 4 months of the road and counting damn it
Cheers Peter
just had some more work done on my 20 this week
put an external gate out the back of my td-06 17c which was internal gate, big new breather tank set up and bigger pod, and profec b spec2
went 357.5rwhp at 19psi
on standard exh mani
and no head or bottom end work for now
i did not think an rb20 was capable of this
Ah, bored in a hotel room waiting for this afternoons drinking session, er i mean Hurling Grand Final...so
TD06-20G
Here is the Mitsubishi version of my compressor , then the 17C
TD06-17C
Are you sure you have a TD06-17C. You seem to be making more power then the compressor map suggests possible. Even allowing for differences in MHI vs Trust turbos
yeh the 17c has a rating of 400hp in internal form, i made 280hp before converting also at 19psi and full boost was at around 4000rpm. but the tune wasnt as good.
mods are:
gts4rb20
gtr injectors
ems stinger
td06 with tial copy gate
cooler, big breather
pretty small budget, biggest gains were had with opening up the back of the turbo and fitting a big pod. all of this is in an s13 silvia aswell, will post graph soon
you made 77rwhp from a tune and changing from blocking the actuator and controlling boost via a bigger external wastegate, at the same boost?
if so, im going to get gate...
Edited by Cerbera
from what research ive done on line it seems that using an external gate and routing it out to atmosphere will actualy allow for hp gains.
i know some one on a supra forum was tired of the noise of the external gate and rerouted it and found on the dyno he had lost 30whp simply by rerouteing the gate into the exhaust.
and its not unusual to gain silly hp via a proper tune, local shop here fuel tuned a blown mustang and made 550whp, not shabby, but when they went back and did some ignition tuning it jumped to a hair over 700whp.
For all you boat anchor lovers
http://www.skylinesaustralia.com/forums/in...howtopic=103095
Ha ha ha nothing wrong with the old boat anchor :( , thanks mate :P
hey i just have a quick question, and im hoping someone can answer for me, i have a bosch 019 intank pump at the moment, which i am maxing out, can someone tell me the next 2 sized up bosch pump that are intank please? plus flow rates aswell if possible. i want an intank pump, not external.
thanks in advance
chris
Meh dont know unless i look up some info i have at home...but my 2c, dont need to
Get a new Bosch 040. They are cheap new, and flow more then a GTR pump, and fit easilt in the std cradle with a 30min tweak.Installation is a DIY 90 min job. If you want to set up a fulltime power supply and relay it takes a bit longer :)
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
