screwed more boost into it this time.....?
Nismoid, I swear I have seen a vid with AC with his ass sitting in your boot on the dyno @ autosalon :thumbsup:
Just saying.
Exactly the same boost, just more timing! The turbo is hitting a brick wall after 22psi :)
  • 3 weeks later...
lucky u guys .. i cant keep traction with mine R32 gtst 93 model on 180kwts 1st 2nd 3rd gear only wheel spin and going sideways.. any clues on that? had the diffs looked at ..nothing that can be done about it ... i got told ?
r33 turbo
r32 gtr fuel pump + injectors standard ecu
drift full exhaust drift pod filter
bc coil overs
14 psi
r33 turbo
bc coil overs
14 psi
maybe look at some wider tyres?
  • 3 weeks later...
r33 turbo
bc coil overs
14 psi
Mate i run 240rwkw and I know what you mean but they're are ways around this slippery slide that you get with r32s.
1) Have a fiddle with your Profec B or alternative ebc and spread the boost as wide as possible over your rev range. This will help decrease the sudden surge of boost and subsequent wheelspin (which is wicked but not when you wanna rape a VE 6 litre)
2) Widen/change your heat cured tyres. I run 245/17s on the rear and 225/17s on the front. Old tyres have f**kall grip (remember this)
3) By a heavy sub box and plonk it in your boot. Don't even have to hook it up but looks better than a pile of sand.
4) When going out to drag, pick your heaviest mate up and take him with you. He'll be good for some grip.
5) Proper use of clutch - foot off clutch before foot on throttle.
6) Put some weight on yourself :D
If your still not happy, buy a GTR!
Well, with a bit more ignition, running the gate atmo I have found a bit more power.
This will be serving as the baseline tune for the install of the Plazmaman plenum (finally) and some Tomei cams over the next two weeks. Will be interesting to see what differences the two mods make. I am hoping for about 285rwkws and a bit more mid and less drop off from the cams and plenum...but I suspect the car will be laggier, more peaky and generally crap compared to how it is now ;)
"...dont fix what aint broke"
Also, regarding traction....this is on crappy Nanakangs
So if you have traction problems with 180rwkws, or anything under 250rwkws then you really need to look at the quality of shocks and spring rates you are using along with the wheel alignment. The vid shows problems with my car under brakes, but thats because I did not bother to put my brake setup back on the car as the intent of the weekend was to get some more running on the setup and check out the tune. A brake upgrade on the rear does not work with std brakes on the front :ermm:
I hear all these people talk about dyno wheel spin yet i've never seen my car do it lol
Im missing out :ermm:
...cause it needs more balls ;)
My last tune, strapped down and people in the car etc still turning them - good for a laugh but yeah not good for anything else
r33 turbo
bc coil overs
14 psi
What spring rates are the coil overs and what tyres+rim combo you using?
If you are using typical jap drift 8kg bullshit on aussie roads and nankangs 215s stretched on 9" rims then its going to spin with 100kw.
I've got 240kw and I can put it down in 1st gear with minimal spin, using fairly soft 4.5kg springs (not 'coilovers'), and 235 federal 595 evo tyres on 9" rims
If your bushes or hicas rods are stuffed and you are getting weird dynamic toe then this will make it sloppy and kick the rear out a lot as well, test the rear wheels for play, will also show up as tramp and horrible vibrations if it is the hicas rods, at least it did with me.
Edited by Rolls
  • 1 month later...
What's the most PSI you would run through an internally stock, but fresh (8000km after full rebuild) RB20DET?
I've got
Full RB20DET rebuild with all the usual honing/blanking blah blah
FMIC
Full turbo back exhaust with performance cat
Greddy Dump Pipe
z32 AFM
Cold air intake
Splitfire coilpacks
550cc injectors
ECU Remap
Garrett GT2871R
Bosch 044
Exedy Super HD Clutch
230.3rwkw on 16 psi...
Just wondering how far I can turn the boost up. I'd run it on 16 usually with the max psi used every now and then.
  • 2 months later...
Did this ever happen?
  • 1 month later...
Well I installed the Plazman plenum and played with a few other things and sadly I cant get the response back :( It seems whilst others have seemed to get good results, I cant say the same. I did as close to back to back as you can...same dyno, same tuner and as you can see no real benefit.
I still have the cams to try with E85, and also have a larger exhaust housing that will let me run more boost...but need to spend some time enjoying it on the track rather then leaving it in the shop waiting to be worked on :)
Well, now that I am back in Aus and the car is back together. I am goign to keep this thread alove :)
So did two track days in two weekends. Did two laps at Sandown and got booted because of noise :( So the following weekend went to Winton and gave it a wrap...
The basics were 19psi, 245rwkws and shifting between 7,400-7,600rpm for 43 laps. I have lost a bit of power as United have stopped selling 100RON so had to wind some ignition of it. Its amazing how sensitive my engine is to ignition, it really loses and gains power with a few degrees....so need to look at getting back on a better quality fuel. Before the plenum install i ran 98 plenty of times on the 100ron tune and no issue.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
