screwed more boost into it this time.....?
Nismoid, I swear I have seen a vid with AC with his ass sitting in your boot on the dyno @ autosalon :thumbsup:
Just saying.
Exactly the same boost, just more timing! The turbo is hitting a brick wall after 22psi :)
  • 3 weeks later...
lucky u guys .. i cant keep traction with mine R32 gtst 93 model on 180kwts 1st 2nd 3rd gear only wheel spin and going sideways.. any clues on that? had the diffs looked at ..nothing that can be done about it ... i got told ?
r33 turbo
r32 gtr fuel pump + injectors standard ecu
drift full exhaust drift pod filter
bc coil overs
14 psi
r33 turbo
bc coil overs
14 psi
maybe look at some wider tyres?
  • 3 weeks later...
r33 turbo
bc coil overs
14 psi
Mate i run 240rwkw and I know what you mean but they're are ways around this slippery slide that you get with r32s.
1) Have a fiddle with your Profec B or alternative ebc and spread the boost as wide as possible over your rev range. This will help decrease the sudden surge of boost and subsequent wheelspin (which is wicked but not when you wanna rape a VE 6 litre)
2) Widen/change your heat cured tyres. I run 245/17s on the rear and 225/17s on the front. Old tyres have f**kall grip (remember this)
3) By a heavy sub box and plonk it in your boot. Don't even have to hook it up but looks better than a pile of sand.
4) When going out to drag, pick your heaviest mate up and take him with you. He'll be good for some grip.
5) Proper use of clutch - foot off clutch before foot on throttle.
6) Put some weight on yourself :D
If your still not happy, buy a GTR!
Well, with a bit more ignition, running the gate atmo I have found a bit more power.
This will be serving as the baseline tune for the install of the Plazmaman plenum (finally) and some Tomei cams over the next two weeks. Will be interesting to see what differences the two mods make. I am hoping for about 285rwkws and a bit more mid and less drop off from the cams and plenum...but I suspect the car will be laggier, more peaky and generally crap compared to how it is now ;)
"...dont fix what aint broke"
Also, regarding traction....this is on crappy Nanakangs
So if you have traction problems with 180rwkws, or anything under 250rwkws then you really need to look at the quality of shocks and spring rates you are using along with the wheel alignment. The vid shows problems with my car under brakes, but thats because I did not bother to put my brake setup back on the car as the intent of the weekend was to get some more running on the setup and check out the tune. A brake upgrade on the rear does not work with std brakes on the front :ermm:
I hear all these people talk about dyno wheel spin yet i've never seen my car do it lol
Im missing out :ermm:
...cause it needs more balls ;)
My last tune, strapped down and people in the car etc still turning them - good for a laugh but yeah not good for anything else
r33 turbo
bc coil overs
14 psi
What spring rates are the coil overs and what tyres+rim combo you using?
If you are using typical jap drift 8kg bullshit on aussie roads and nankangs 215s stretched on 9" rims then its going to spin with 100kw.
I've got 240kw and I can put it down in 1st gear with minimal spin, using fairly soft 4.5kg springs (not 'coilovers'), and 235 federal 595 evo tyres on 9" rims
If your bushes or hicas rods are stuffed and you are getting weird dynamic toe then this will make it sloppy and kick the rear out a lot as well, test the rear wheels for play, will also show up as tramp and horrible vibrations if it is the hicas rods, at least it did with me.
Edited by Rolls
  • 1 month later...
What's the most PSI you would run through an internally stock, but fresh (8000km after full rebuild) RB20DET?
I've got
Full RB20DET rebuild with all the usual honing/blanking blah blah
FMIC
Full turbo back exhaust with performance cat
Greddy Dump Pipe
z32 AFM
Cold air intake
Splitfire coilpacks
550cc injectors
ECU Remap
Garrett GT2871R
Bosch 044
Exedy Super HD Clutch
230.3rwkw on 16 psi...
Just wondering how far I can turn the boost up. I'd run it on 16 usually with the max psi used every now and then.
  • 2 months later...
Did this ever happen?
  • 1 month later...
Well I installed the Plazman plenum and played with a few other things and sadly I cant get the response back :( It seems whilst others have seemed to get good results, I cant say the same. I did as close to back to back as you can...same dyno, same tuner and as you can see no real benefit.
I still have the cams to try with E85, and also have a larger exhaust housing that will let me run more boost...but need to spend some time enjoying it on the track rather then leaving it in the shop waiting to be worked on :)
Well, now that I am back in Aus and the car is back together. I am goign to keep this thread alove :)
So did two track days in two weekends. Did two laps at Sandown and got booted because of noise :( So the following weekend went to Winton and gave it a wrap...
The basics were 19psi, 245rwkws and shifting between 7,400-7,600rpm for 43 laps. I have lost a bit of power as United have stopped selling 100RON so had to wind some ignition of it. Its amazing how sensitive my engine is to ignition, it really loses and gains power with a few degrees....so need to look at getting back on a better quality fuel. Before the plenum install i ran 98 plenty of times on the 100ron tune and no issue.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
