  • Replies 635
^^ You don't make sense.
Exactly what i said. R33 turbo models are not GTST,they are GTS25T. only R32 came GTST just the same as R34s only came GT-T.
Wankery technical i know but facts is facts.
well then people should refer to their cars as ECR33, BNR33, etc if you are going to get technical about abreviating models
Difference being there isnt ECR33 stamped on the rear end is there?
I know im bein a technical dildo but i like technical stuff.
But yeah a GTST is a GTS R32 Skyline with an RB20DET
And yeah ill admit i don't Prance around saying GTS25T all the time,but atleast i know the secret truth.. lol
On a side note: is the 34 a GT and not a GTS because of the fact its a different shape and design from the GTR as opposed to R32 and R33 being of the same sort of design?
There is not R34 GTS iirc
Yeah i was asking if anyone knew the reason for this.
badges dont mean shit vl have holden badges on the back
but they have a rb30 in em they dont have gts30t on the back do they
And we have a winner..
If ls1 engined commodores have chev badges, shouldn't rb30 vl's have nissan badges?
My hardcore commo loving friends did not like that question lol.
Do you REALLY want to see a Nissan badge on this?
Neither would I.
And Reading the argument about the GTS25T, I knew that that is the model of the car but when people ask "is it a GT or GTST", do you really want to reply "Neither, its a GTS25T"?
R34 only came out in the GT, GTT and GTR(vspec etc).
Neither would I.
VL Calais is a nice car but its not Nissan just like a holden is not a chev.
And if i want to be technical,yes i do want to say it lol.
And no one seems to have read my question right. i was asking if 34 is GT and not GTS because of the fact the GTR isn't essentially the same car with bigger guards. GTR 34 has shorter wheelbase as well.
Neither would I.
Bahahahahaha very true
Yes it is. The chev badge pisses me off for one reason only, and its that the owners wont admit its there purely because it looks nice, in fact a hell of a lot nicer badge design than holden. IF they really wanted to get picky about their badges and motors, hell they would have a gm badge on it, not a chev badge. That has the same significance as a pontiac badge, but the pontiac badge doesnt look good. The owners have them because they look nice, thats it.. if only they would man up and admit it.
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
