I popped into Jaycar yesterday and purchased the kits for;
The Independant Electronic Boost Controller
products_uploade..._7575.jpg[/url]
Digital Fuel Adjuster
The Hand Controller for Digital Projects
And the RS232 cable to join the Hand Controller for mapping/programming
It has been about 3 years since I built my last electronics kit (a 400 watt sub woofer amp and processor for the home stereo). So I figured I would start with the easy one, the Hand Controller. Instructions where very explicit, quite easy to read and the pictures are very clear. Certainly a big improvement over the DJ stuff (sound and light) that I used to build to help pay the uni fees. Including reading the instructions and the basic electronic theory, it took me less than 2 hours to build the Hand Controller.
I will post up some pictures tonight.:)
https://www.sau.com.au/forums/topic/61207-jaycar-boost-and-fuel-control/
  • Replies 1k
Posted Images
So is that where you got your nick name from ?  From the old DJ years :)
J
Oh no, I was a roady. Not pretty enough to be a DJ. And yet not quite nerdy enough to hide in the back room soldering all day.:cooldance
Watching keenly, been tempted to purchase these kits for awhile.
What solenoid would be suitable for the boost controller for cars that arent fitted with one? AKA cef.
Believe it or not, the solenoid Sillycoon Chump recommend is the Nissan, just like the one on the Stagea. The instructions even have a picture of it. So stick up a "wanted" on the forum, there are plenty of R33 GTST's with EBC's that aren't using their standard solenoids. :)
Shoot why did I say that, now the price will go up. Just like the R32 GTST wastegate actuators, they used to be cheap and plentiful until I opened my big mouth:kick:
I've just ordered a throttle position sensor kit as well from the wholesaler that jaycar buys from. As much as I think Julian's an eccentric english teacher, I really wanna try out his intelligent BOV design.
If anyone needs jaycar kits at wholesale prices then let me know. I don't mind helpin out an SAU hobbyist.
should I start a group buy (it gets even cheaper when ordered in qty's of 5) or are you happy with wholesale...
anyways, enuff hijacking of SK's thread.
A quick picture of the Jaycar Hand Controller on the ashtray lid, can still get to the power socket. Looks OK, easy to mount, bit of velcro on the ashtray lid, some on the back of the controller. It will then be low enough to allow the cup holder to function as normal.
But when I add the RS232 cable..........the plug is nearly as big as the controller itself.
There must be an RS232 flat cable, with a small plug, preferably black. So I can tuck it back behind the controller and in through the ashtray. I asked the Jaycar guys and they didn't have such a cable in their cattledog. Some of the computer experts out there may know of a cable that may be suitable.:P
SK - I think the best way to go WRT cable - is to get a DB25 to DB9 flat converter. Then you get a small DB9 to UTP converter - Run UTP from the HC to the fuel computer and use what ever cables you want at the FC end. It's still going to be a bit cumbersome.
Maybe replace the DB25 on the HC with a UTP connector ?
I've been eyeing those Jaycar kits for ages - Will keen to know the results.
Cheers,
Cheers,
I'll have to check the circuit diagram, but I was told by the Jaycar guys that the communication was 2 way and used a number of discreet connections. I took that to mean I couldn't combine any wiring and had to run 25 discreet links. JE used a flat cable I noticed in the test photos. Looked like the ribbon cable that I use to connect hard drives to mother boards in the PC.
I'll find the photo scan it and stick it up over the weekend.:(
Ahh - I see. I did assume that it was a standard RS-232 connection. If that were the case then you would only need 7 or 5 or 3 wires - depending on how it serial connection was designed.
But yeah - if they are non-standard, discrete connections you will have to refer to the circuit diagrams -
IDC connectors (hard drive cables) might be the go
SK why don't you just hardwire the plug in... ie cut the plug off and solder the cable to the terminals inside the box, and have a small hole with the wire coming out of it.
Yeh thanks! That's a good idea, except I have already soldered the plug onto the board.:(
PS I am not really planning on permanently leaving it in the Stagea anyway. So I might not worry too much.
I'm really interested in how the thing actually performs in terms of spiking, holding boost. More importantly how difficult it is to set up for say an ordinary person.
Well, the theory is;
It can't not hold boost (as long as the turbo is up to it of course) because it can completely stop any boost (airflow) reaching the wastegate actuator. This is because the boost control solenoid (pnuematically) sits in between the plenum and the wastegate actuator. Unlike most boost controllers (EBC of not) that bleed off air and lower the pressure that way. Put another way, Sillycoon Chump's design is in series with the wastegate actuator whereas most other EBC's are in parrallel.
Spiking, is pretty much a factor of the electro mechanical response of the solenoid. Plus how fast the processor can interpret the results and send instructions to the solenoid. Once again Sillycoon Chump's design has an interesting advantage, it doesn't use boost to give feed back, it uses injector duration. This means the boost control processor is not waiting while airlfow is buffered though pipework to a MAP sensor. As soon as the injector cycle changes, it knows the airflow has changed. And that happens once for every two engine revolutions, that's 50 times per second at 6,000 rpm. That sort of response is physically impossible using airflow to drive a MAP sensor.
What is really interesting is the ability to have 2 completely different boost maps with up to 128 load points in each. That doesn't mean simply "high" and "low" boost settings. What it means is I can have the same max boost, but have one boost map (say for wet weather) that brings the boost on slower. I can have lower boost as well if I want, but I don't have to. Pretty cool huh?
I did a fair bit of research before I decided to give these a go, and they have some very interesting features. Looking forward to giving them a real world try out.:D
PS; The interpolation (smoothing) algorythm between the 128 load points looks to be quite effective as well.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
