the stock maps are fairly rich for protection reasons but it should still enter closed loop on low throttle. as long as 02 feedback is turned on of course. 250km's to a full tank is resonable in an un-tuned state
Quick Question...
- AVC-R
Or
- Boost Controller Kit
for Power FC?
Is it personally preference of would the boost controller kit for the PFC be better cause its also controlling the rest of the engine as well as being cheaper than the AVCR (AVCR = $580) - (PFC Boost Controller = $400)
Give me your thoughts...
so no disadvantage/advantage over the two... apart from having an AVCR on my dash and someone decides the would prefer it off my dash and in their corolla :D
It has a bit of a wank factor... Also with the PFC do you have to leave the commander connected all the time, can you like take it on and off at will if its in the way or soemthing?
After reading the faq, I still needed some more convincing on the PFC with an auto, so i've made a new thread so as not to bring the conversation into here:-
http://www.skylinesaustralia.com/forums/in...showtopic=97698
So yeah, i want to know once and for all if the PFC will work with the auto.
Cheers.
hey ive have plugged in my power fc and its hasent been tuned yet.
the engine light stays on and the car constantly stalls. it also feels like its skips and hops going up through the rev range. all was fine with my stock compter.
i need to keep the powerfc in fow a couple of weeks till i get it tuned, is there anything i can do to fix it? like reset it or sumthing?
make sure the boost controller kit is turned off (says that in the faq) and if that doesnt make the engine light go off, try a full reset via ETC then turn the key to ACC, turn off boost control kit and then start car and let it idle for 20 minutes. follow the procedure correctly for first time "init" of the powerfc as it has to learn the idle
I dont know if this has been covered but I just found you that you can get number rating for the knocking levels with your car.
Just press the UP arrow, and it will show digits for knocking. So basically it will show you the peak, in a digit and not just upon the bar graph
updated:
added boost control kit hookup
added boost control kit configuration
added boost display without using boost control kit
added apexi other piggyback systems
corrected grammar with powerfc pro
expanded more on apexi boost control kit functionality
Paul
I bought a AVCR boost pressure sensor from Nengun. I have a 3 pin plug for my power FC. It reads boost but its wrong. I have my set my boost pressure at .65 bar via the power fc to read 20psi at my guage. My low boost is set at .50 bar.
I believe something is wrong with the boost pressure sensor? I had to manually wire it up as it didnt have the correct plugs. Any ideas as i have double checked the wiring.
sorry robo im a bit confused. i dont know for a fact the avcr map sensor is the same, it should be. can u give me the denso part number from it. the map sensor should attach to the 3 pin harness. the boost solenoid should attach to your stock wiriing. when you goto setting, boost what option is highlited and whats it set to ?
heres one for ya, my battery went dead flat and car sat there for 2 weeks, i jump started the car from a charger/starter pack and now engine light is always on and car stutters while cruising every couple of seconds. We went to a local tunig shop and they had a customers car with brand new power fc and we used that commander as i dont have one for mine. It plugged in and just came up with the apexi logo and thats all it would do. Are the commanders only suited to that specific ecu of should it have worked? Also any ideas on wether something has been reset or blown due to the flat battery then jump start? driving hard it seems to run fine with no stuttering but its when you sit on a constant cruising speed and also does it worse under less load. also after working on it tonight the voltage off the battery is at 14.8-15.5 volts whilst running and the battery light is now on!!
Bet ya this stumps ya!! lol
Edited by DRIFTPIG
    • So my rb is finally having more problems. 2 issues here but I'm here to just to mainly discuss the rattle noise. The other day when I turned on the car and when I take off or go in reverse, there is a temporary rattle noise but when I cruise, boost, idle it's completely fine no rattle whatsoever. I've also done all the servicing, all the health checks you can think of and it all passes with flying colours.  Also the rattle doesn't increase with rpm, it's only at a very certain rpm (slightly above 1,100rpm). My other car also has the same issue every once in a while. Changed the oil recently, no difference. Even took my oil to a lab and everything was quite good surprisingly. Timing belt changed a while ago to. Had the car on the hoist and can't see anything obvious. Tightened a couple of nuts on the exhaust manifold a couple of months ago. 2 different clips uploaded. One of them was supposed to another issue but I'll save that for another time. Thought I'd see if anyone had this same noise before, it's a bit hard to diagnose while it's intermittent. If I'm not mistaken, I think I had this a while back but can't remember exactly. I was thinking if it's doable I'll get someone to hold the throttle cable at 1,100rpm and hopefully it replicates the sound. rb25det rattle only.mp4 rb25det slow start + rattle.mp4
    • Haha wow, yes they do! Will sort tomorrow.
    • Yeah I’ll know when I take it for a test drive and I’ll double check the turbos as well when I have a look at it again.  Just thought maybe they might have done something in the head cause it looks like they’ve taken off the rocker covers 🤔 Thanks for your info!
    • As Duncan mentioned it's likely a remapped ECU, like the the one listed in the link I post earlier:  https://minkara.carview.co.jp/userid/444260/car/444612/2099320/parts.aspx He quoted 444PS with an unopened engine and twin GT2510s @ 1.1bar boost... sounds about right?
