nope they are not compatible. you will need to go for a piggyback (apexi safc, greddy emanage) or a remap of the stock auto ecu (nistune, dr drift remap, toshi remap)
i believe another option is to use the pfc but then you need an add on box for the auto and if i remember right you then have to shift the auto manually, depending on how much you want that would probably be the better way to go any way.
Hi everyone,
First of all, a huge "thank you" Paul for what you've done: great FAQ!
I have a question: I'm used to tune L-Jetro PFCs, and I'll soon have to tune my first D-Jetro. I noticed there's an extra fuel map called "base map" which seems to be tuned.
Can someone tell me what is that map for?
Oh, and BTW, is there someone here who has the default std map of a RB26DETT D-Jetro (R33)?
Thx!
the problem with using a manual ecu on an auto car (ie PowerFC on auto skyline) is that when the autbox changes gears the ECU doesn't know
so the timing doesnt change during gearchange. on the auto ecu the timing is dropped during gearchange to let the auto box change gracefully.
with the manual ECU the timing stays the same and the box suffers stress from a fully loaded engine during gearchange.
now this gotcha only applies to nissan's as toyota powerfc exists in auto, at least for the chaser
the JZX100 powerfc to suit chaser comes in auto and it has lots of logic and suppport for the AT gearbox
you can even change the mapping when it changes it gears in the menus and edit the gear splits (f**ken ace).
this from my understanding is because the toyota has its gearbox logic inside the main ecu, where as nissan is in another computer
apexi either didnt care about the auto box (lets face it, auto skyline isnt common) and either couldnt be bothered, didnt see $ in it or wasnt enough demand, or too complex?
Hi everyone,
Thx!
this is from the apexi documentation
there is no need to find a default rb26 djetro map, as it the powerfc comes with one
if it's second hand, perform a DATA INIT before using it and the default maps are loaded. if its new it already has the default maps
Thx a lot for the information. So if I got this right, if you fill the main fuel injection table with "1", you should be able to run 14.7ish all over the map. And if not, you should proceed to minor mods in the base fuel map in order to get 14.7 afr (at least in part throttle).
And only after that step, mods to the main fuel table should begin.
Am I right?
(oh, and do you have the p24 they say to refer to?)
Edited by Jobi
you use the fuel and inj correction maps to tune the car. its only if you find you can't get the results you want or run out of correction where you adjust the base map
hi kila, you need to use the nissan boost control kit
double check on your wiring loom if you have wire #25
this is used by the apexi boost control kit
ie 25 runs to the solenoid and the other is 12v (25 is a switched ground)
without wire #25 the boost control kit will not work, so double check before purchase
and as far as i know the EL hand controller will only suit FCC3 which is new style
so it wont work on RB20 AP eng powerfc as it needs FCC1 or FCC NT
ok thanks i was looking at the nengun website and they have 2 diffrent nissan onces the
415-A001 and the 415-A013 i was planning to buy one this week i just didnt want to get the wrong one.l
Paul....quick question.....
your FAQ is excellent. One thing I do in every car is take the timing to 0 between about 4000 and 2000rpm for that childish poping that I love.
However, when off the throttle the injectors always drop to 0, to get things going along nicely I need to hold the throttle open a little which gets the fuel throwing again.
Do you have the same effect? and if so any suggestions other than stuffing with TPS closed position?
unsure sorry i put my timing back to normal for a while and forgot about the 0deg idea
    • Has equal chance of cleaning an AFM and f**king an AFM. I think you can work out what happened. When the Hitachi ECU sees the AFM die and goes into the associated limp mode, then it will start and run just fine, because it ignores the AFM and just runs on idle maps that will do what it needs to get it going. But there is no proper load signal, so that's about all it can do. My suggestion? If you don't want to go full aftermaket ECU, then get some R35 GTR AFM cards and some housings to put them in, in the stock location, and Nistune the ECU. Better to do a good upgrade than just replace shitty 40 year old tech with the same 40 year old tech.
    • So my car was recently having trouble starting on initial crank, I would need to feather the gas for it to start up but besides that it would start and run fine. So I clicked the idle air control valve (with throttle body cleaner) and cleaned the MAF sensors (with MAF cleaner). The start up issue was fixed and now the car turns over without the assist of the throttle, but the car is in limp mode and wont rev past 2.5k RPM. From what I understand the IACV would not put the car in limp mode, so I am to believe it is the MAF sensors, but it was running fine before and now I cant get it out of limp mode. I cleaned the MAF made sure the o rings were seated properly. Made sure the cables were plugged in properly, the cables also both read the same voltage. Does anybody know why this is or what could be causing this or how to get it out of limp mode?
    • Ooo I might actually come and bring the kids, however will leave the shit box home and take the daily
    • Thanks. Yeah I realised that there's no way I'd be able to cover the holes with the filler, it would just fall through. Thanks again @GTSBoy!
    • That was the reason I asked. If you were going to be fully bodge spec, then that type of filler is the extreme bodge way to fill a large gap. But seeing as you're going to use glass sheet, I would only use that fibre reinforced filler if there are places that need a "bit more" after you've finished laying in the sheet. Which, ideally, you wouldn't. You might use a blob of it underneath the sheet, if you need to provide some support from under to keep the level of your sheet repair up as high as it needs to be, to minimise the amount of filler you need on top. Even though you're going bodge spec here, using glass instead of metal, the same rules apply wrt not having half inch deep filler on the top of the repair. Thick filler always ends up shitting the bed earlier than thin filler.
