Referring to the photo regarding to PFC settings 3. Does any 1 know why my Air Flow settings would have been changed from the default of 100% to 0.0% in all 8 boxes when I was
having every value as 0.0 means correct the load axis to 0
this will make the car run like ass and im surprised it starts
put them all back to 100.0
http://www.paulr33.com/powerfc-emulator/me...t_afm_ramp.html
the value as covered by the pfc hand controller emulator is correction scaling
this influences the final load axis the pfc uses to select IGN/INJ correction off the maps
I have an EL hand controller in my hot little hands.....however both my cars with PFC at at mechanics atm. I am 99% certain it is the same as the old controller, just coloured and ricier.
updated
added confirmation new EL hand controller supported models (all PFC's except for Toyota JZX100 Auto)
awaiting pics from duncan of new EL hand controller
OK, had a chance to have a look. All functions are effectively identical to the normal HC (contrast page is different but has the same purpose).
The firmware is at least a little smarter, my old HC used to come up blank when being used via a PS2 extension cable whereas the EL comes up with "communication error". But all the actual tuning and monitoring functions are the same as the regular HC.
anyway pics are pretty crappy (no interior light in the race car :thanks:)
attached:
serial number
version number screen
start up logo
el contrast control
even so...it is very ricey and I'm not sending it back :down:
question...
I have a pfc numbered: pfc rb25 9810-0049
Now i took the car to be tuned,but the tuners software wouldn't recognize the computer,said i would need a hand commander unit for him to tune it.
So i borrowed a mates commander which was off a pfc numbered:ecr33 and what ever numbers i cant remember,which worked fine.
Now im trying to buy my own commander,just brought one numbered: fcc nt9607-0464....BUT it doesn't work,just goes to the apexi screen and stops there,but from everything ive read,this unit should work...???
Could someone please point me in the right direction..
anyway pics are pretty crappy (no interior light in the race car :huh:)
attached:
serial number
start up logo
el contrast control
even so...it is very ricey and I'm not sending it back :)
thanks
that looks heaps better
and good to confirm it is in fact FCC4
as this hand controller works on every version of powerfc except toyota Auto which is even bettter
ie ap eng, pro, normal spec and every car
i will add to the PFC FAQ shortly
thanks again
i might get one too, looks a lot better
question...
check your serial #
FCC NT should work on PFC RB25 powerfc
A hand controller from ECR33 serial # powerfc should NOT work on RB25 PFC serial # as they are different models
ie
PFC RB25 needs FCC N001 which is FCC NT
PFC ECR33 needs FCC X001 which is FCC2 or FCC3
you can buy the new EL version which will work
tryed the hand controller again,with the same result...
Pulled the cover off my pfc and stick on the chip was: fc rb25-2
So i dont know whats up other than buying the new el model..
very frustrating
if you said you used a mates hand controller and he has PFC ECR33 serial # then yours is labelled wrong
its the only thing that makes sense or its a non-std powerfc or something else is wrong
N001 or FCC NT should work on PFC RB25 XXXXXX
X001 or FCC3 should work on PFC ECR33 XXXXXX
the first two digits of the serial # is the build year
so yours was built in 1998 apparently
Has anyone had this type of problem before?? My 33GTR Powerfc Pro is not linking up with my handcontroller or FC datalogit. My GTR has a normal FC running at the moment so i know the hand controller and datalogit are fine, but the pro wont link up although starts the car and runs, abit rough as its a unknown tune from the prevous owner... When i purchased the pro 3years ago, i hooked it up and everything worked fine, i varified it was the PRO and let it sit ever since... Anyone had a similar issue??
i have a PFC pro have had no such drama's mine was brand new
maybe try a full INIT
Thanks for the reply madaz i cant get into the menu to init it unforuntely its funny it worked fine a few years back now nothing...
  • 3 weeks later...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
