lol yeah its been in the works for the last month, its sat over there still.
waiting for de-reg papers will apply for import app when i get. should be next week.
and the wait begins.
its been the dumps since i sold the evo, i need some rb26 power. :rofl:
Will be a loong wait.
  • 4 weeks later...
im in the process of importing myself a r32 1994 GTR or 93 GTR
i know that compliance is around 3-4k
but what do they actually do in SEV's complaince ? whould it be better for me to get one of the few remaing 1989 gtrsand give it a engine rebuild ?
say i get a 1989 GTR for around 16-18k (easier to compliance )
or a 1993 GTR for 22k -24k
I know SEV's require no accident damage cars and all mods have to be returned back to stock car. do i have to pay for all the parts to be returned back to stock or is that included in the compliace ? or course im not going get a highly modifed GTR
with massive turbos injectors pump coolers....etc im looking for a stock ish 32 gtr
wat acutally does my 3-4k compliance pay for ?
wat would be more worth it ?
Use SEVS. The later model car will be in better shape all 'round. As you're looking for a stockish car, that won't be a problem, just finding a RAWS will be the biggest hassle...
Pretty much everything is shagged on an 89 model. Bushes, motors, turbos, hoses, rotors/pads, fluids, etc. I'm just passing on the 1989 perspective. Perhaps make a post in the Skyline specific discussion folder and get some 93/94 guys to share what their cars are like.
There is most likely more late-model cars available for you to choose from as Aust and Canada have sucked up most of the 89 models. Any decent 89's would have long gone from Japan IMO.
My 2.2c,
Mark
RAWS stands for Registered Automotive Workshop Scheme (iirc). The RAWS are the guys that use SEVS to import a vehicle on your behalf. They will liaise with DOTARS, arrange for import approval. The vehicle will be sent directly to their workshop and returned to stock/standard and complied before you are allowed to drive it anywhere. Any performance parts are to be destroyed (not resold/refitted) and this is in legislation. We all know plenty of guys take the upgrade parts off, have the engineer look over the car/just in case the DOTARS rep chooses to inspect that particular vehicle, and then replace the parts. It's a stupid rule.
With respect, you need to have a good look over the DOTARS import web pages, and also check out the import folder here, there is LOTS of great info and knowledgable (sp?) guys around to assist. Guys with R33/R34 would be the best guys to talk to for SEVS/RAWS info.
Afaik, there are only a few RAWS endorsed by DOTARS atm. The process takes anywhere up to 2 years for some workshops. Until recently, the only R32 RAWS was a dealership in Brisbane that only complied cars that were going onto their showroom/yard.
Hope that helps, and if anyone out there has a different take/better info, feel free to correct,
Cheers
Mark
Ok guys, In the driveway all cleaned up. :)
Came with quite a few goodies such as a 100mm aftermarket FMIC, HKS FCON V ECU, Tein Coilovers, HKS intercooler piping and HID headlight conversion just to name a few.
Here's a couple photo's..
HID goodness
Interesting paint!
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
