the lot must go..
big plans, no money.
RARE
late model 93.
Engine + turbz (77,000km)
gearbox + new clutch
interior (no rips no tears)
dash
thats the big stuff taking offers on the lot
5% of the sale of every item goes to SAU.
  • Replies 77
1992/3 R32 GTS-T4 parts I need to move so far:
1x R32 Bonnet in White. Excellent condition, - $500
4x S15 (currently on my GTS4) 16" wheels in Silver. Good Condition $400
1x R32 front bumper in white - good condition . - $150
1x R32 low km full RB20DET + wiring loom + turbo. - $1700
1x R32 GTS-T4 gearbox + new clutch low km $800 (same as GTR)
1x Full Interior (front & rear seats) $600
1x R32 Dash inc cluster (77,000km) $1100
1x Carpets and lining $300
OTHER PARTS AVAILABLE - just ask. All reasonable offers considered.
I need to strip this thing. All i want is running gear and chassis.
this is stage ~99999999999.... weight reduction, big plans, little cash.
if anyone else can think of something to buy off this car that will save weight.
post.
I will offer 5% of all proceeds from the sale of the parts to SAU. =)
Judd do you have the surround that goes up around the centre console and gearknob - its a black/grey piece, awkward shape - I need one !
Also - the front bumper whats it look like?
stock,
but i do have x1 Fujitsubo Legista R to suit
x1 Veilside 90mm exhaust
x1 Buddy Club 97mm straight through race exhaust.
and no i am not a parts company. All is for personal and private use.
email
[email protected]
5% of every sale item goes too SAU
Mate,
I'm after the passenger side seat rail or perhaps the whole seat if you dont want to seperate?
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
