  • Replies 96
its got gt-ss turbos
260 tomei cams
power fc
ported head
jun pistons
rods
bearings
jun springs valve
custom piping
4'' exhaust
700cc injectors
100mm trust intercooler
type r bov
sard fuel rail
sard fuel reg
twin 910 fuel pumps
os tripple plate clutch
22psi
blitz id boost controler
360awkw!
cheers ,BEN
260 tomei cams
power fc
ported head
jun pistons
rods
bearings
jun springs valve
custom piping
4'' exhaust
700cc injectors
type r bov
sard fuel rail
sard fuel reg
twin 910 fuel pumps
22psi
360awkw!
cheers ,BEN
...and 115mph don't add up?!?!?!?!
Adrian
yeah, I was thinking the same thing. my stock GTR runs at 108mph. it has:
stock turbos
stock intercooler
stock dump pipes
.9 bar boost
Power FC
oh, and me for a driver, so it's already handicaped.
Congrats on the 11.7 though, that is a very good time for that mph. was that on slicks?
wat sorta time was that 108MPH at tho mmmgtir?
from memory it was 13.2 :Oops:
also ran a 13.010 at 106mph :Oops:
60ft 1.81X (forget exact) on both those passes.
with that 60ft and that mph I should be able to get a 12.XXX maybe a 12.7. the only thing holding that up is me.
It was only my first time drag racing the car. :rofl:
well yer.. from wat i understand about the GTSS's are they are a low to mid range turbo dont really have much top end.. but than again.. anyone feel free to proove me wrong.. depends wat there shifting at i guess.. would be nice to see a dyno sheet of the car as the power figure is rather nice
Sorry guys, but 360awkw should be good for more like 125++ mph.
Adrian
I agree with that statement , i did 11.7 @120.85 mph in a 33 gtr with under 300 awkw and ordinary 1.8xx 60 ft due to wheel spin .
Adrian
Like wise Adrian, I agree with you on that one.
With the turbo setup and the cam setup, it should be at least 120mph, with each run the mph should slow get better and better. As you learn the feel of the car.
Either their is some restriction, either intake or exhaust. Once your motor get up high into the rev range, or it needs some serious tuning work for top end power. eg, Fuel / timing.
What about traction? If it was a full track wheel spinning 115mph I would understand ?
But still a good effort.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
