i go to curtin uni in wa, and on one of the network drives there was a vid clip of these guys in the middle east with a vt commodore and another type of car (dont ask me what it was) and they were cutting sick as drifts in them. one guy got the vt to 360 about 5 times, and then pulled out and kept going. in the middle of the highway they would drift the vt across a 5 lane highway and drift it back, it was seriously mad shit. then one guy nearly killed himself; he drifted the vt across the road, then came back, but too far, man, the smoke from the handbrakie was unreal (he managed to pull out, but only just, he nearly rolled it beacuse it was so far sideways)
im telling ya, these middle eastern countries have got a thing for these commodores
']In Indonesia the VL Calais was released there with an RB20DE. They also got Kingswood 202's (their version of a muscle car). Japan also got the Kingswood chasis and released their own version with a 13B in it.
u for real about the kingswood 13b combo?
since japan don't really need utes, those sorta carsa are a bit of a novelty over there to them, like their awesome cars are to us
i'm interested to know why japan doesn't need utes?
I wonder if someone will import a SS from Japan back to Aus...
^^^ Japan doesn't need 'Aussie style' utes...
Holden, at very best, will be an oddity in Japan. A sedan version of a Corvette so to speak, and how many Corvettes do you see rolling around in Japan? You could count them on one hand on a daily basis. I'm sure there are Corvette clubs in Japan with members numbering in the hundreds, but theres just no impact on the market whatsoever... so what would a sedan or even ute version be? An oddity, nothing more. Nice try Holden! :rolleyes:
I've wanted to see what some Japanese workshops could do with a VL Turbo for ages. If us simpleton Australian guys can be getting 8's and 9's. I wonder what those lads would get out of it? Some pretty crazy stuff I'd imagine.
Whats this? A Single Cam 3 litre? Pathetic!! haha
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
